0 Members and 1 Guest are viewing this topic. Read 69699 times.
I recently made a new parallel gauge to set tone arms so they are parallel to the record surface. Wayner
I find it interesting that the supposed "rational types" who claim to rely on measurements, are in denial when the evidence comes from an "observational reviewer" like me.
Here's my own home-made Tonearm Parallelerizer. Sorry I'm the world's worst photographer (I won't blame in on my camera). It's just a transparent ruler with grid lines on it, available at most office- or art-supply stores. I've just taped a piece of white paper on the back along with supports cut from index cards. You just place your tonearm on an old record and put the Tonearm Parallelerizer behind the tonearm. View it from the side, and you can easily tell when the tonearm is parallel to the record. You can leave the arm set there, as recommended by most manufacturers, or just use it as a starting point for fine-tuning.-Bob
What a bunch of crap indeed. The software measures the angle. It's not a guesstimate. What IS a "bunch of crap" is the notion that you have to change the SRA for every thickness record. No one suggested that...oh except you, to dismiss the entire discussion. Good going! In order to change SRA 1 degree on a typical 9" arm, you'd have to move the rear of the arm by a full 4mm. Therefore, once you set SRA to 92 degrees with an average thickness record, you don't have to mess with it. But if you are using a Shibata or other hyper contact stylus and you're not at 92 degrees or close there is empirical evidence showing that you're greatly increasing distortion. The research has been done.I find it interesting that the supposed "rational types" who claim to rely on measurements, are in denial when the evidence comes from an "observational reviewer" like me.so if you wish to hear a bunch of crap, then by all means call this discussion one!I'm sure you can hear difference every time you sneeze, especially if you loogie all over your records. But hey! who cares! It's all a "bunch of crap."
My Ortofon has a Fritz Gyger FGII stylus, would that be considered a hyper contact stylus?Jim C
Yes. So are all the micros. Finelines and linetrace are extended contact, but not as much as a micros. Most of this stuff actually comes from 1981. If you're really interested.....http://www.audioasylum.com/audio/vinyl/messages/1240.htmlhttp://www.vinylengine.com/phpBB2/viewtopic.php?t=25794&highlight=degrees
With a moniker like yours, Neo, you might be interested to hear what I'm hearin and feelin right now . . "You did it, you did it" by Roland Kirk from We Free Kings. On vinyl, most assuredly. Best, old chap.(later) Checkmate- Shelly Manne and His Men (Contemporary). Nuthin but soulful playin you can feel by the note from Richie Kamuka (tenor sax) and Russ Freeman (piano), et al. If it ain't about feelin . .
John Risch explained this in a clear manner, so I am more convinced, and I'd never denied the importance of SRA.However, all the cartridges I bought in the past, instruction manuals say the top of the cartridge body should be parallel with the record surface, I am guessing the SRA has already been built into the cartridge stylus tip. I'd better check with a backlight.
