0 Members and 1 Guest are viewing this topic. Read 69723 times.
The machine needs to have all of the necessary and correct adjustments to bring your experience closer and closer to bliss, even if we can never achieve the ultimate goal. Is it not worth pursuing?
I really don't understand your resistance.
Conversely...I really don't understand your insistence.
I am insisting that the idea is worth discussing.
Neobop, I guess my point is that your 90 degree SRA would be just as incorrect for these different cutting angles as 92 degree SRA. If 92 degrees sounds better than 90 in some systems and for most records than what is the harm? I really don't understand your resistance.
Maybe our record collections are very different. What about those exceptions, don't play those records?Being a member of the set and forget camp, I can understand your endorsement of this approach. My records vary greatly. Sure, sometimes I can listen for hrs and not have to mess with VTA, especially if I'm listening to ones on the same label around the same vintage. But, if I feel like playing one of those "exceptions", the prospect of losing my perfect VTA/SRA is no cause for hesitation.
