0 Members and 1 Guest are viewing this topic. Read 91647 times.
Got an email; just use same link (copy it into URL and then edit and change to "3161").. I wouldn't use 3160 if I were you. if so, please report to us any issues. My $.02 says you'll find one or two.
Quote from: ted_b on 26 Jul 2009, 09:21 pmGot an email; just use same link (copy it into URL and then edit and change to "3161").. I wouldn't use 3160 if I were you. if so, please report to us any issues. My $.02 says you'll find one or two.When I try that link and change it to 3161 as you suggest, it asks me for a Username and Password. Did you get that?
Quote from: gman on 26 Jul 2009, 11:34 pmQuote from: ted_b on 26 Jul 2009, 09:21 pmGot an email; just use same link (copy it into URL and then edit and change to "3161").. I wouldn't use 3160 if I were you. if so, please report to us any issues. My $.02 says you'll find one or two.When I try that link and change it to 3161 as you suggest, it asks me for a Username and Password. Did you get that?yes, same username and pwd as you used with 3160. If you didn't get one, then ping Sonic.
I've been playing with Amarra for a few weeks and I like the sound compared to itunes. Has anyone tried turning the volume up on itunes while Amarra is running? Very interesting results...
Have you tried manually setting the wrong resolution for iTunes, then playing Amarra? it plays real slow...a cool effect. Just kidding. Amarra is not to be played with iTunes volume (at any level) at the same time. The phase and tonal issues are numerous. Playing with professional EQ controls is one thing; playing two different music players at the same time and using their time delays and tonal differences is, well, "not recommended?".... I've spent huge $$ to get rid of these. I'm not about to add them!
have you tried it? they don't like play one second behind each other. choose a song from itunes and toggle the itunes volume up and down until you get the desired effect. if you start and stop it it will create a delay between the two programs...it does create an effect like reverb or delay but only a minnor one. it's all about experimenting
3162 available. Downloading it now.
no, just did the URL edit and see if one downloads.
I posted this earlier in this thread. If you have a supported Amarra license (demo or otherwise) you got an email from Sonic regarding release 1.01 (Crimson posted the text earlier too). It included a link to zip file 3160 and a username and password. Just edit that link to say "3161" or "3162" and send it. Use the same username and password they gave you. I check every few days.
