0 Members and 1 Guest are viewing this topic. Read 91561 times.
If you check the file in the Amarra folder, it should be the updated version. When installing a new build, your desktop icon will not get updated and will be a previous build (the last time you dragged or copied it from the Amarra folder to your desktop).
Quote from: Crimson on 6 Aug 2009, 12:42 amIf you check the file in the Amarra folder, it should be the updated version. When installing a new build, your desktop icon will not get updated and will be a previous build (the last time you dragged or copied it from the Amarra folder to your desktop).Thanks for the help. I see what I was doing wrong. I was clicking on "Desktop" > Amarra. Which is the icon. right? When I go to applications > Amarra > Get Info it then shows what you have. Thanks!
For those who aren't aware, Vincent Sanders of VRS Audio Solutions was the fellow who worked with Sonic Studio to bring Amarra to fruition, and is their authorized dealer/representative. While Amarra has some plug-and-play virtues, most will have many questions regarding operation and playback. For anyone who has interest in Amarra, I highly suggest contacting Vincent to get the best information about how Amarra will work in your system. As I understand, the $500 discount is available through the end of May, and will be honored through Vincent as well.Vincent's number is 702-263-8094 and his e-mail is "[email protected]"
This is normal behavior. If you manually change the sample rate, the music will play back faster/slower. As a rule, don't play with the sample rate. Let Amarra adjust your computer/music server automatically, and let the DAC respond. Your DAC should be able to determine the incoming sample rate and adjust automatically. I am not familiar with the Wavelength gear, so can't comment much beyond that. Let us know how this works out for you.
I would check with the manufacturer of the DAC for a qualified answer, but my understanding is that this is NOT correct. Oversampling is something that certain manufacturers do with DACs, but that is an internal process. Your DAC should automatically switch sample rates, but if you have to manually set it, then the sample rate should be set to be the same as the incoming signal. What happens when you switch from 88.2 to 44.1 to 96 etc.? Does the DAC adjust automatically?
Great. So there is no need to intervene with your DAC. Just let it do it's magic. Oversampling is something that certain DACs do, but again, that is an internal process. I can't speak to whether this process adds any benefit, real or perceived. Enjoy Amarra! Did you buy it? Which version?
