0 Members and 1 Guest are viewing this topic. Read 91627 times.
Where did my post go? Why was it deleted?
Quote from: jtwrace on 24 Aug 2009, 10:13 pmWhere did my post go? Why was it deleted?Which post are you referring to? Nothing has been deleted.
Quote from: Crimson on 24 Aug 2009, 10:20 pmQuote from: jtwrace on 24 Aug 2009, 10:13 pmWhere did my post go? Why was it deleted?Which post are you referring to? Nothing has been deleted.Really? hmm. I posted about the upsample conversion in Amarra. That's all!
Quote from: jtwrace on 24 Aug 2009, 10:21 pmQuote from: Crimson on 24 Aug 2009, 10:20 pmQuote from: jtwrace on 24 Aug 2009, 10:13 pmWhere did my post go? Why was it deleted?Which post are you referring to? Nothing has been deleted.Really? hmm. I posted about the upsample conversion in Amarra. That's all!Well, it's not here or in the IGW. Try posting again.
Different thread/different Circle, dude! http://www.audiocircle.com/index.php?topic=68494.msg662258#msg662258
Over the weekend, I compared my Macbook Amarra(Ver.3170) set up to the same tracks(16/44.1 & 24/96) played back via PS Audio PWT. Preferred the SQ of the PWT.Yes, I know the PWT isn't a music server, but I don't mind getting up to change disks if it soundsbetter.
Quote from: jhm731 on 24 Aug 2009, 10:05 pmOver the weekend, I compared my Macbook Amarra(Ver.3170) set up to the same tracks(16/44.1 & 24/96) played back via PS Audio PWT. Preferred the SQ of the PWT.Yes, I know the PWT isn't a music server, but I don't mind getting up to change disks if it soundsbetter.Will you say more about this -- how would you describe the sonic differences between the two?And what was the system configuration re: interface from computer/PWT to DAC, and which DAC?TIA.-Dan
Well there is the problem. This is hardly a fair comparison. You are relying on a very low-quality DAC in the Macbook. You are running analog from this low quality DAC into your system. A fair comparison would be to use hardware approved by Amarra connected by FireWire or USB. Only then can you draw conclusions.
I see .... jhm731, can you please be specific about what you are doing exactly? Is it Option 1 or Option 2 below?Option 1 (my prior assumption):- Amarra/iTunes source- Audio Midi Setup must be correctly set for sample rate- ANALOG out from Macbook via 1/8" to stereo RCA inputs on Tact DAC- Tact DAC analog outputs to analog sound systemOption 2 (ted_b's assumption)"- Amarra/iTunes source- Audio Midi Setup must be correctly set for sample rate- DIGITAL out from Macbook via 1/8" to Optical digital cable (using SPDIF standard for data transmission)- Optical digital cable connected to optical input on Tact DAC- Tact DAC analog outputs to analog sound systemAlso, as I alluded to earlier, even if we are dealing with Option 2, this is still not a fair comparison. Closer, but still far from fair. I know because I actually tried this when I upgraded the system in our showroom. We were using an Apogee Ensemble Firewire interface with Amarra, which I was not fond of. So I ordered the Lynx AES16e card and a Lavry DA11. Before the Lynx card showed up, I connected the Lavry DA11 directly to the Mac Pro using an optical/toslink cable. I was underwhelmed. The improvement with the Lynx card was very significant.So ... For reasons I do not want to get into (because I am not smart enough to understand them, let alone explain them), a digital output from the Macbook's DAC is not comparable to the digital output from a high quality digital interface. It is may be due to a host of issues, including jitter, poor timing, lack of clock data being sent to the DAC, etc., but again, I am not smart enough to explain that end. All I know is that from heavy listening, you have to use a good interface with Amarra.
