0 Members and 1 Guest are viewing this topic. Read 91625 times.
public:Dave:Music:Puscifer:_V_ Is For Vagina:09 Sour Grapes.aif
V_ Is For Vagina
Sorry to hear that Dave. I guess Amarra is a work in progress.
I sent Jon a list of what works and what does not so he can see perhaps what I am facing here. It is odd in that there appears to be nothing consistent from either set... some that have "_" work while others do not. Some that have [] work while others do not... oh well. iTunes sounds quite fine here, but so does Amarra. 3162 works with all that files that 3177 does not... I could go way back to 3139.
My advice to any one wondering about whether Amarra presents value is to try either the free trial (there will be gaps in your tracks) or the $50 iLok based trial. I doubt you will head back to what you are using now, but see what you think.
Has anyone tried Rowmote, specifically with Amarra?
Found a minor bug last night, although I'm not sure if it's Amarra or the OS: when switching between multiple external dacs the output is not routed to the newly selected dac even though it's highlighted in both Sound Preferences and Audio Midi Setup, and the name of the dac is correctly displayed in the main Amarra window. Amarra/iTunes needs to be restarted when switching dacs.
