0 Members and 1 Guest are viewing this topic. Read 51449 times.
Recently purchased a stock 1210mk11 and am looking at modifying the t/t. I've got the arm booked in for internal and external re-wiring with AudioOrigami (in the UK) and am also in for the KABUSA fluid damper and either the Isonoe feet or the Soundcare super spikes. I currently use a Funk 5mm Achromat but notice a lot of people recommending the Isoplatmat with the Herbie's (or similar). Does anyone have any views on whether I should drop the Achromat for the Isoplatmat etc or will they work together?
Didn't want to have to do it but looks like i'm getting rid of the Achromat. Isoplatmat here I come!!! I'll get it on hi-fi for sale etc see if I get any takers.
Looking forward to getting the arm re-wired. Understand it will make a big difference, especially when tied up with the fluid damping.
Being on a slightly limited budget I'm unsure re: isonoe feet. Plenty of good reviews but the costs are slightly prohibitive. Would I be better sticking with the stock feet for the minute and saving or will the Superspikes make a reasonable fist of things? Reviews seem very positive.
I'm on record as an Isoplatmat pimp. Its the best analog tweak I've encountered, got one on each of my TT's. Before any tweaks comes careful setup, clean records and a clean stylus. Still on standard feet on a pass through wall that is dead solid.
Right, sorry, I didn't realise you were directing the question at me I've not heard the DL-301II personally, but from previous experience of using a multitude of Denon cartridges I have a fairly good idea of its sonic characteristics. Whilst I'd always be wary of buying cartridges on Ebay, for obvious reasons, the 301 should be a good buy. I'd expect it to have a nice fluid sounding midrange, sweet sounding top end, and decent bass. It will not be bright or clinical sounding in the way of some Lyras and Ortofons, as that's not what Denon MCs are about. Musically, it should be a joy to listen to, but make sure that your phono stage has enough gain to cope. In my experience, low output Denon MCs prefer a step-up transformer into a MM input than just an MC stage on its own. It will likely work best with Denon's own step-up transformer shown here on the Audiocubes website:http://www.audiocubes2.com/product/Denon_AU-S1_Audiophile_MC_Step-up_Transformer.html?osCsid=a3a38b99f36aecec62b93456ce01d1d7But it's not cheap. Still, if you want to do things properly...
Just put a Funk acroplat under the thick rubber Technics mat and sounds excellent. Sounds better under the rubber mat than on top.Phill
