0 Members and 3 Guests are viewing this topic. Read 51383 times.
Off topic (excuse me Marco) I ordered a maple cutting board from the seller you linked John - it will come home in my daughters luggage in September! It does serve as a useful guide - UK price of the exact block TCG featured in his thread about isolation is £95 - 190 bucks - go figure
Marco, You have my utmost admiration for going to the trouble of importing the KAB Technics into the UK. Our friends / fellow audiofools across the pond have difficulty understanding our import tarrif and VAT structure - it makes US (and far east) sourced kit very expensive
TCG's 'mastic spray' is (I think) what we call underseal - though obviously it must go on pretty thinly and is a modern formulation if it can be over-painted (I found that in the link provided in Johns thread about it). Similarly, Plasticlay is Plasticene - took me a while to work that out and be comfortable I wasn't making a BIG mistake. Of course, it is quite inoxious and easily removed if you don't like it.
Where abouts in UK are you Marco? I would love to hear your setup....
lcrim,Thats good news on the longer clamp shaft...I can't put together a mental image of the potential problem you describe, however...any chance you could snap a pic?
I forgot to mention it but Kevin exchanged my record clamp w/ one that has a longer shaft so that I can use it with the isoplatmat and standard thick rubber mat on the platter. I have to be careful because the shaft extends a bit below the center surface of the clamp and could screw up the surface of a record.
I have also been using the Mr. Clean Magic Eraser as a stylus cleaner. If used carefully, my Benz Glider L2 is nude and looks very vulnerable, then a brush with isopropyl soaked stylus brush, the stylus is extremely clean. I bought a loop just to check this out and its amazing how much gunk a stylus can pick up.
BTW- I keep asking this, what's your take on the Denon DL-301II. @ $255 from a Japanese reseller on Ebay it really looks interesting. I have the Glider and messing about w/ woodsyi's MC-3 led me to it but I just wanted a change of pace. I have a Goldring Eroica LX in my other setup and the 301II is also light enough and compliant enough to work w/ the Dual CS5000 there. Sorry, the conical 103's just give me pause, afraid what they would do to the vinyl surface.
