0 Members and 1 Guest are viewing this topic. Read 50969 times.
Hi dmckean,I'm still trying to get the time to write it. When I write the review, I want to do it properly and make sure it's a fair and true reflection of the table's abilities against other T/Ts I've used, and some that I'm familiar with in the current market place. Unfortunately this is my busiest time of year, work-wise However, I'll have a go at answering your question.The first question I would ask before we go any further is what type of cartridge do you intend to use with the Technics? Your answer will have a significant bearing on the recommendation I give. And what type of mat system do you intend to use?When you supply me with this information, we'll take it further.One thing I will say in the interim is that you should, if funds permit, factor in the cost of the separate PSU, and prioritise the inclusion of this, as in my opinion it makes the biggest improvement of all the KAB modifications.Speak to you soon.Regards,Marco.
Having had my stock arm re-wired by Audio-origami I can vouch for this route. Haven't heard the modified Rega however and so can't offer a subjective comparison.I'm quite interested in adding the outboard PSU and wonder whether it's possible to build one myself rather than buying the KAB one. I imagine it's relatively basic. Anyone got any ideas?
Hi Marco,Don't knock yourself out too hard to get the review written, it's no big deal.I really haven't decided what I'm going to do for a cartridge. My current modded Rega P2 setup is pretty modest and the Ortofon Super OM 40 I currently have is the most expensive cartridge I've ever owned. I'll use it and my Cambridge Azur 640P phono stage until I can upgrade. I was 19 when I bought the P2 and my income was a lot different. The motor on my P2 is slowly dying so it's time to upgrade. As for a mat I plan to try the isoplatmat/herbie's combo everyone else is liking. Maybe someone will make a custom ceramic platter for the Technics someday. Then we wouldn't need multiple mats.Thanks for the advice on the PSU, I was planning on having it wired with the power socket and do the upgrade later but I think I'll take your advice and just buy it with the table.
I think I understand and I'm just surprised the modified KAB arm is that good.
Marco, who made the counterweight for you and how did you design it so it was spot on for the cart you were intending to use?
Marco... you raise more questions for me than you answer.. then again I am just getting back into vinyl after 30 years so clueless is a good way to describe my knowledge of things TT related. I have limited funds, looking at SL-1200 here are the options I was going to get; Arm rewire, fluid damper, strobe eliminator, KAR/Ortofon ProS30, if budget only allows one more 'option' what would you recommend getting?
Also, what difference does it make if the counter weight is brass or something else?
Is your brass CW a different weight than stock?
If you recommend a different cartridge than the ProS30, what would it be?
