0 Members and 1 Guest are viewing this topic. Read 45920 times.
Is there anything else, physically, besides the resistance, inductance, and capacitance inside the device? Any other materials, or just the resistor. If just the resistor, I would agree with you; something appears wrong. If there is more, I would suggest to do an analysis of those materials.
How do I insert an image?
The problem with that scenario, Daryl, is that according to the description (link was provided earlier in this string), it was used by the military in Sonar systems of subs.I am not saying this is exactly the same device, but it seems to me the crux of the matter is if the statement about being used in sonar systems is true or an outright lie (assuming the same device was used in sonar systems). Afterall, if that statement is an outright lie, it does not look good for the Bybee. If true, then maybe a little more exporation is needed, such as examining the ceramic used.Just a thought.
We would want to know not only did the government actually use these devices but also DID THEY WORK.
The paper used in the Bybee does not appear to be ERS paper. The paper seems to missing the nickel coated strands of carbon fiber which is the key component in ERS paper. For what it is worth a 6in. long 0.5in wide strip of ERS paper can be wound around unshielded IC's and speaker cables with a noticeable,although subtle positive effect. Yeah,I know, the effect of ERS paper on the transfer function of a signal through an unshielded wire probably cannot be easily measured either. Single blind testing of ERS paper within context of my own stereo system has yielded consistent 100% positive identification results. Scotty
