0 Members and 1 Guest are viewing this topic. Read 46059 times.
Sorry, I didn't see Mike's data. So, it's basically a very expensive sham. I do note that others here on the board say that bybees work well, so those links just posted were for reference only. Now, I think that with many things like this, one could be convinced to hear something that's not actually there. But under the proper conditions (two modified SBs, one with bybee and one without, and the ability to switch between the two), I think one could verify the analytic tests with subjective tests. If the subjective tests are different, then one would have to ascertain why.
I am taking no sides, but shouldn't we at least know what it is before we form a lynch mob? As DB mentioned earlier, his testing is "basic".We haven't even established what it is made of. Is it just a resistor, a combination of rare earth metal oxides in a ceramic form, or something else? If rare earth materials are used, how are you going to identify those materials?"He says it is nothing more than an extremely low ohm resistor of very high qualityused in the medical and aerospace industries. He priced the resistors out at 50 cents to one dollar depending on which type."I wonder how it is a high quality resistor if it only costs 50 cents? My last dealings with high quality power, 25 watt, resistors, cost me many dollars. One can purchase a cheap power resistor for a 50 cents.Before we lynch and asassinate someone's character, shouldn't we have some firm, definite, reliable info?
Quote from: Steve on 30 Mar 2007, 05:43 pmI am taking no sides, but shouldn't we at least know what it is before we form a lynch mob? As DB mentioned earlier, his testing is "basic".We haven't even established what it is made of. Is it just a resistor, a combination of rare earth metal oxides in a ceramic form, or something else? If rare earth materials are used, how are you going to identify those materials?"He says it is nothing more than an extremely low ohm resistor of very high qualityused in the medical and aerospace industries. He priced the resistors out at 50 cents to one dollar depending on which type."I wonder how it is a high quality resistor if it only costs 50 cents? My last dealings with high quality power, 25 watt, resistors, cost me many dollars. One can purchase a cheap power resistor for a 50 cents.Before we lynch and asassinate someone's character, shouldn't we have some firm, definite, reliable info?Anytime anyone has some real data to post on this please feel free to do so. The data I have taken clearly speaks for it self. d.b.
Bob,I have Bolder analog modded unit with silver bybees on the analog out. If you have Wayne's mod, I can send you mine for you to do a direct comp.I have used Bybees but I am fully opened to accept the fact that it's nothing more than a placebo gadget. Let's see if we can hear the difference in a blind test.
Guys, the resistor brand, in the Bybee I smashed at least, is Pacific, model 1711, 5% tolerance. The resistor is brown, round, plastic cased, with large, probably nicely oxygenated copper leads.
Are you ready to build a few chokes Josh? And Steve: what other measurements do you have in mind? Please be specific if possible. d.b.
First off, identify what one has. That hasn't been done yet. Do you have other instruments other than a simple voltmeter, LRC meter, and scope? The next question is if it is quantum mechanics, are you going to be able to measure everything? If go, great.So far, I haven't seen you condemn the Bybee, but others already have, which is what I have been concerned with. Are you changing your positioin?Is the resistor the only element in the Bybee?Quote from: Dan Banquer on 30 Mar 2007, 10:40 pmAre you ready to build a few chokes Josh? And Steve: what other measurements do you have in mind? Please be specific if possible. d.b.
Quote from: Steve on 30 Mar 2007, 11:24 pmFirst off, identify what one has. That hasn't been done yet. Do you have other instruments other than a simple voltmeter, LRC meter, and scope? The next question is if it is quantum mechanics, are you going to be able to measure everything? If go, great.So far, I haven't seen you condemn the Bybee, but others already have, which is what I have been concerned with. Are you changing your positioin?Is the resistor the only element in the Bybee?Quote from: Dan Banquer on 30 Mar 2007, 10:40 pmAre you ready to build a few chokes Josh? And Steve: what other measurements do you have in mind? Please be specific if possible. d.b.Steve: The resistor is not the only element as the measurement showed, an inductive element and what appears to be a capacitive element that you will note at 100 KHz. Note the inductance is decreasing, probably due to capacitance between the wirewound resistor windings, also note the small change in resistance.Now if you could please tell us how Quantum Mechanics effects any electrical measurement I think many of us would be very interested. d.b.
Now Steve; I'm just trying to understand something here. If quantum mechanics play a role in any electrical measurement then please inform us as to how this happens, and what electrical measurement we should do. I'm not into lynch mobs, I was sent this unit for test, and as far as I can tell this is a wire wound resistor. So simple me concludes that if it sounds like a duck, walks like a duck, and looks like a duck, it must be a duck. Now I realize that this is high end audio we are talking about so it's really not a duck it's a quantum visualization of a duck. d.b.
Large Bybees are:a 25W 0.025 ohm resistorencased in a ceramic tubewrapped in ERS paperwrapped in plasticsealed with copper end tubes.They measure like a resistor and are a resistor.
