0 Members and 2 Guests are viewing this topic. Read 615650 times.
Where do you get that Teflon tubing? Basic google searching has only resulted in bulk quantities that are quite expensive.As an alternative: how about coating the soldered pot leads with a big glob of hot glue? Definitely cheap and easy, but is there any downside?
That's a big box for a small amp. What's all going on in there? And what are you using for a power supply?
How hard do you think it would be to convert that board to a single-channel 100 Watt version? I believe this is called "parallel bridge tied load" or PBTL. Seller "audiobah" on ebay has a "Amplifier board, TPA3116 Class D, 2x50W or 1x100W - Stereo or Full PBTL" (current link). I.e. you can buy it pre-wired for mono. But it costs more than the Yuan Jing, and the YJ just looks nicer to me.I'd like to have the TPA31xx sound in a higher-power package (>100 watts at 4 ohms ideally). Two of these in PBTL mode in the same chassis running off a single power supply would be nice I think.
Looks like the two silver "bricks" are 12 volt power supplies wires in series to get 24 volts.Wind Chaser, if this stuff is new to you, then you are in for a treat! If not...sorry for the newbie advice.I'd get some standoffs, if you don't already have some. I like the aluminum 4-40 one's on ebay. You'll need some 4-40 screws as well. These amps are VERY light, and if you secure them on a small piece of plywood or the like, then the cables won't drag it all over the place.Then you can connect the power supply, speaker wires, etc. to the amp, plug in the PS, and enjoy. From there, you can go to the next step...a real enclosure. You can reuse the standoffs to mount in the case.Again, sorry if this doesn't help. The neat thing about these amps is learning all the other stuff, like switches, jacks, binding posts, ...
I am using my trusty modified Power One SMPS set at a 12.5V DC / 6A output. I don't think I'll need more power than this for my 98dB Klipsch Forte IIs unless someone really convinces me that I need to upgrade to more power.
Rhing... I am confused. Doesn't this board require 24V DC?Yaun Jing site specs:Voltage Range: DC 18V ~ 26VRecommended Voltage: DC 24V / 2 ~ 6A
If you review the Texas Instruments TPA3116D2 datasheet, the voltage range for operation is 4.5 V – 26 V, so a 12V power supply with 3A or higher output will power the amp fine, especially with more efficient speakers. Some people use less efficient speakers that require more power, so a higher wattage power supply like a Mean Well RS-150-15 or RS-150-24 SMPS might be better. However, some on the diyAudio.com forum thread on these amps have claimed that using anything higher that 21V results is degraded sound quality.
Turns out this $49 Chinese 6N3 tube preamp from ebay is absolutely stunning with the 3116. I thought I liked the 3116 just as an integrated amp but there's no comparison to the sound with this tube preamp. I tried the 3116 with a Bottlehead Foreplay III expecting even more but the magic wasn't there. If I hadn't already built them as separates I'd put both in the same case.
I got one in the mail. We'll see how it does... The TDA7297 is still one of the most transparent things I've heard.
I played around with t-amps for few years as a hobby, just got my first chip amp TDA7297, hooked it up to small desktop speakers. To my ears it sounds surprisingly good. I am excited to connect to my main full-range and see. I agree it is excellent and cost me $7.
Rhing... Will your new TPA3116D2 board fit in the same size box you have used for your other small amp builds? BTW/ what are the dimensions of the new stock board? Also, any more listening impressions?Thanks,Lacro
Can you provide specific links for the input caps and inductors? I'm getting to the point where I can neatly replace some stock parts, but have no confidence in my ability to pick technically appropriate replacements. I do have some Panasonic FC 1800uf/25v caps that I planned to put into place for the power caps and power supply terminals.
