There is also a new pre-amp based on the buffer design that will give you 18db of gain. It sounds just like the buffer but with a little more dynamics. It is a perfect solution for anyone that can't get away with a passive buffer design because they need the gain. We used on of these on Sunday in our room at RMAF and it was outstanding.
Is that determined by the type of amplification you have in your equipment chain? Just curious.
It depends on the input impedance of the amp, the input sensitivity, the amount of gain needed to drive it, and the output impedance of your source. At RMAF the big Reference Line amp that we used on Sunday needed some drive and the new pre-amp matched with it excellently.
