0 Members and 1 Guest are viewing this topic. Read 300571 times.
Are you looking for a pre-built completed unit from Gary, or just the kit to roll your own?
Thank you very much. In your opinion, is this a good way to address the impedance differential between my minimax and beta22? It seems to be a better sonic (fewer parts) and cost effective solution than adding a pre-amp to the mix.
Arn at Goldpoint even suggested I could add a selector switch to switch in/out the buffer stage.Do you have more information on how to do this and what to order? I'd love to have the option to bypass for a/b testing and home theater use.Thanks!
RodicWelcome to AC. " Using the Sovtek 6H30PI with 12v selected "6H30 is 6V tube, so you may try to switch back to 6V and see if the noise still there. Dodd buffer with ClassD amp does make a tube hiss sound but only your ear next to the tweeter.
I didn't go there with him, but here's the Goldpoint switcher page.http://www.goldpt.com/selector.htmlIf using just a 2 pole switch in between the volume pot and buffer, with one switch output leg going to the buffer input, and the other going directly to the output female RCA, there would be a back feed into the buffer caps when switched over to the "no buffer" position...problem? You would have to ask Gary on that one. Another solution would be to do the above, but just have two sets of output female RCAs, one set off the buffer, the other directly off the "no-buffer" position of the switch. Of course then you would have to move the output interconnect cables whenever you switched over. PITA, but simpler.I guess a third option would be to get a 4 pole switch and switch in and out both the input and output of the buffer. That would be more contacts in the signal path, but may be ok.
...The only problem remaining is, the CTEK still cannot be connected while I'm listening. Inconvenient, but not a show-stopper. However, everyone else on the forum doesn't seem to have the same issue with listening with the charger connected. Any Ideas?
