0 Members and 3 Guests are viewing this topic. Read 305787 times.
I finally picked up a pair of these buffers. I'm looking for a small form factor battery to power them. Any recommendations? I only need 2-4 hours of battery life with 6H30's, thanks.
Definitely giing with the 1 in 1 out $150 kit. What is the least expensive way to power it? The battery kit is $250, that's more than I want to spend.Also looking for a very inexpensive DAC, any suggestions?ThanksMoto
praedet,Thanks, I am a Prime member. I assume the AH ratings don't directly coincide with actual run time. Can you leave the charger hooked up at all times?Is the Musiland Monitor at the same quality level as the DODD?Sorry for all the questions, this is new territory for me.Moto
So I can plug my OPPO directly into the DODD and save some money? That would be great!I will still need volume control correct?Thanks again for all the help
