0 Members and 1 Guest are viewing this topic. Read 57736 times.
I ask because regardless of the sub I used, I can locate a single sub.
If the sub has a 24 dB per octave crossover at 100 Hz, its output will be down by about 100 dB at 1.5 kHz.The ear does not process sound like I think you are envisioning; much of it is counter-intuitive. De-correlation at low frequencies is desirable in most situations.
I have a question:Am I really missing anything by not having a sub? My speakers go down to around 35hz and do a fantastic job with bass. I am a near-filed listener and don't get any further than 8ft away from my speakers. Granted, I'll miss what is below 35hz, but how much is there below that? (Good question , acutally!) Are there that many instruments that can play below 35hz?
Here is what my in-room response ended up being by utilizing more than one subwoofer and a little PEQ:It sounds vastly different! With the large peak at 50Hz everything was bloated and smeared, but now...well, its like a totally different system, for the better.
Wait, so you are saying phase isn't important below the crossover frequency?
No, your not missing anything.Except I do remember that I used to have a lot more cables, amplifiers, filters, test recordings, and constantly adjusted the subwoofer level(s) for different recordings. You are missing that. (Just making a little counter point for the fun of discussion. )I guess the real moral of the story is that it's up to you to decide what you prefer. How far are you willing to go to achieve technically perfect bass? Does it improve the overall listening experience? No one can answer this for you.I'm actually open to trying it one more time. We'll see.
Looks nice... Measured at one position, or averaged across an area? Many folks "tip up" the low end response a bit. I adjusted mine that way and found that it sounds a bit better (my subs don't go as low as yours, though):
That is quite the output at 17Hz?Wayner
Nuance, that's an amazingly flat spectrum, even with EQ.
