0 Members and 1 Guest are viewing this topic. Read 57717 times.
I completely understand everything that is being said- but cannot get over the thought that a mono sub system is oversimplified, even with multiple placements. I think it must improve many things and sacrifice others. I listen to allot of bluegrass. There are times when bass is stronger out of one or the other channel. (AKA: Stereo separation) I don't want a sub smearing it all over the place. If it's supposed to be in the left channel, shouldn't we keep it there? I don't want it all over the place. Same goes for the other recording I mentioned earlier on.
I suspect you are hearing things higher than 150 Hz. It is generally agreed that that is the lower limit for localization (as long as there are no harmonics and nothing is rattling).
i'm w/niteshade on this point. i have been able to localize a mono sub, even when crossed over as low as 80hz. the only time i have heard a mono sub not degrade soundstaging is when it is centered directly between the mains, preferably in the nearfield. but, stereo subs, imo, improve soundstaging, instead of not simply degrading it. i have never heard mono multiple subs done per gedlee; maybe my opinion would change. but, i'd still be more apt to run multiple subs in stereo.doug s.
harmonics past the fundamental xover point caused this.. lower the xover point or try a steeper slope
And how do you know this?
I ask because regardless of the sub I used, I can locate a single sub.
Yes, changing the phase of one or more subs can flatten the overall response and reduce ringing at the major modes. In my experience the effect was relatively small, but this is certainly one of the recommended tools for optimizing the overall system response. Perhaps Earl can add some more detail.
Here is a link to a typical subwoofer's specifications on frequency response: http://www.madisound.com/catalog/product_info.php?cPath=45_338_381&products_id=8434Download the PDF and you'll find that most subs go out to 1.5K-2K. They are then duplicating what your mains are creating. Xover at 80-whatever, will not stop the dual reproduction, and blurring the lowest frequencys of the music. Your using the "wall of sound" theory in your systems and because it kind of sounds full, does not mean it's accurate. It's 180 degrees the other way of the simple speaker systems.Wayner
If the left main speaker is producing a tone at 1.5K, then the subwoofer is also creating a tone at 1.5k...
Now add a sub that is out of phase and OMG, we just have a barrage of stuff heading towards the listener.
