0 Members and 1 Guest are viewing this topic. Read 58053 times.
But.... I'd happily give someone an unlimited budget on 2-channel loudspeakers and give me a $2000 limit on subs/EQ and a pair of loudspeakers and I can beat the unlimited 2-channel budget in blind testing nearly 95% of the time over a given listening area.
Sound Labs uses a similar distributed resonance with their electrostatic panels. Their idea being rather than try to tame a single resonance of the large panel, divide it up into different sections and let the smaller individual resonances sum into the voice of the speaker.
Is the "multiple sub" idea similar in that you are summing the room peaks to get an average response, or are you placing subs everywhere there is a null?
I would think you should be able to get away with some small low powered subs if you are summing a bunch of them.
In practice, the subs end up going where there's a place for them, and it works out just fine.
Wow.
Getting good performance is just a matter of using the tool right. But.... I'd happily give someone an unlimited budget on 2-channel loudspeakers and give me a $2000 limit on subs/EQ and a pair of loudspeakers and I can beat the unlimited 2-channel budget in blind testing nearly 95% of the time over a given listening area.
Of course the final issue that isn't solvable with any loudspeaker or room is the fact that recordings are not mastered universally the same. Especially in the low frequencies you have significant differences in how they were mastered/recorded. You are ultimately limited by what is in the recording and since there isn't a universal standard for studio monitors or the room, there ultimately is no standard for the bass that goes on the recording.
There is something I have not noticed being talked about enough and that is the possible problems with phase. I have experienced this even with stereo bass towers, but I would think it would be much worse with summed mono sources.
Here is the problem I have with smaller rooms and jumping on the separate subs band wagon. A 20 hz cycle wavelength is 56.6 feet, 30Hz is 37.6 feet, 40 Hz is 28.3 hz, 50 Hz is 22.6 and 60 hz is 18.8 feet, rounded of for my pleasure. A 10 x 14 foot room will not allow these frequency nodes to develop, as the room is physically not large enough to accommodate the wave lenghts. Now you will get 3/4 or 1/2 wave lengths, but I can't imagine the phasing problems or other stange nodes that will develop with the hopes of obtaining heavenly bass bliss.I also find it interesting how one bunch of AC'ers are single driver folks, looking for that perfect point source sound (which I truly respect) and another group that insists on more drivers then a Greatful Dead concert.I am not making judgment here, but I will say there is more to great sound that a flat frequency response, because there are always design trade-offs. You just can't have everything, the laws of physics get in the way.Wayner
