0 Members and 1 Guest are viewing this topic. Read 57871 times.
Thanks for the comments guys. So would the crossover in a Rythmik FS12 sub for example be considered a "quality" unit or would I have to step up to something like a Behringer be the best option?
But again, in fairness, your speakers require subs, they aren't a standalone solution.
Yes, it is all about the system - which includes the room! Having multiple low frequency sources smooths out the bass response by reducing the large peaks and notches in the response as measured a the listening position(s), which invariably occur in average size listening rooms. You can have 3 or 4 subs overlapped with the mains, and still maintain a flat frequency response. The piano keyboard goes down to 27 Hz, and the four strings of a bass guitar (or double bass, for that matter) cover the range from 41 to 97 Hz. If you want to hear all of the notes across that range at the same volume they were originally played at, you need multiple low frequency sources. Even if your mains are flat down to 20 Hz, the addition of one or two subs (properly integrated) will improve your bass response.Oh yeah, I guess I am guilty of committing that second blasphemy as well, but I would rather do that than have absorbers hanging all over my living room.
You still need absorbers or you won't affect decay time. Just because you have more even response throughout the room doesn't mean you affect physics. There's still going to be boominess caused by ringing. Show a decay plot with and without absorbers, and you'll see what I mean.
To expand on the posts from Elizabeth's to this one, is there any thought to bass being bad for some rooms? In other words if one is limited to none or little room treatment, the room is not large, and/or you have cohabitant problems, maybe you should go with a speaker rolling off around 60hz and no sub.
i have poked around some on dr. geddes website but i am having a hard time locating a good source for his multiple sub setup. i am curious to learn more about this. can someone give me a link?
i wouldn't want to be hi-passing my mains thru a sub amp's x-over. but, i am not sure a behringer (unless modded) would be a step up. i would look at the offerings by marchand - really quality stuff, for the price, imo. consider the xm9 or xm44, unless you have a lot of cash; then you could choose one of the tube x-overs...http://marchandelec.com/doug s.
I posted something earlier in this thread, but here is what my current response looks like with 2 subs + Geddes Abbeys:
My results are the same about putting the mains through a crossover. Have you used a Marchand crossover successfully this way? I find the use of subs extremely problematic in the hook up. Splitting the output signal from the preamp, degrades the sound and somehow causes bass cancellations in the mains, above the frequency being augmented, irrespective of placement. Maybe I haven't stumbled on the right placement, but it doesn't seem possible hooked up this way. I'm about to try a different hook up configuration, so I'll see.On the other hand, years ago I heard a system that used electrostatic speakers run full range and 2 large Entecs were uses to augment the bass. Ahead of the Entecs was an Audio Control Richter Scale III. This was a crossover/bass EQ, with 5 bands from 100Hz down. It came with a calibrated mic and a warble tone generator. The Richter Scale was run off a tape out, so it didn't degrade the main output. Results were astounding. I suspect very good results could also be had in this way, provided the main speakers didn't distort badly with with a full range input. Speakers and speaker designs vary widely in this respect. It might take lots of trial an error with an EQ, but I think it would be possible. I'd be reluctant to invest the money for a Marchand, in the hope that it wouldn't degrade the mains.neo
Also, if you've ever been to a LIVE rock concet, there is bass. In the end, THAT'S what we're trying to reproduce.
The GedLee enthusiasts on this forum run their speakers full range. The active crossover (whether it be attached to the subs or separate like Behringer DCX that I use) is only used for low pass on the subwoofers themselves. Nothing is mucking with the mains at all.
