0 Members and 1 Guest are viewing this topic. Read 212219 times.
Quote from: vintagebob on 3 Sep 2009, 12:57 amWelcome aboard Sedah. That sounds like a nice system. Do you HAVE to tease with the veneer?! What will you use to drive that small "forest"? What do you need to get done before they show up?Ok...let's get this thread back on track. Bob,A small forest? That is so funny. I hope you don't mind if I tuck that away in my memory bank for use at a later date. Sedah,You have the beginnings of a great system.
OK guys, help me out with some DAC info please. Nuance made a comment about adding a DAC to my Airport Express (I thought he only talked about Salk speakers ). How would I add a DAC to my system listed below?Take Toslink out of the Airport Express (AE) to an Inday Switcher and then SPDIF out to the DAC (assume AVA Ultra DAC?) and from there into the SC-05 AVR? Something like that? Run the OPPO to the same switcher? I would still have to use HDMI out of the OPPO for all of the multi-channel music.Then what do I do for a preamp? This is an evil hobby.
I really do have other interests and hobby's...
I sooooooo need a dedicated room.
Isn't a preamp's tape output loop essentially an HT bypass? The AVA gear has synergy. Since you have an AVA amp and are considering an AVA DAC, I would suggest looking at the AVA preamps. Additionally, AVA is a custom shop (limited to the chassis and chassis color). If asked, Frank will install two phono boards (of different models, even)in a preamp, for example, or he will install a phase inverter bridge in a preamp. These options aren't necessarily advertised, but if you ask.... Also, with AVA, Frank offers a choice of tube, hybrid, or solid state components across a large portion of the product line. While the components are voiced the same, there are distinctions between tube, hybrid, and solid state products, and because Frank builds each component as ordered, a customer could purchase a Transcendence 8 (tube) preamp with an Insight (solid state) phono board, for example. The T8 preamp won TAS's Editors' Choice Award.
OK, I think we're closing in on it.OPPO/Airport Express to Inday switch to AVA Ultra DAC to Parasound 2100 preamp w/bypass for HT use?
Nuance,you have 712 posts711 for salkdo you have any other interests?Not to be a pain but mixing it up could be fun!reminds me of those av123 automatonscome into the pool ...the water's fineMike
What's it to you? Nuance is OK. If you don't like his posts, then don't read them. As far as other interests, I know he operates a hair salon in Tokyo.Quote from: topround on 3 Sep 2009, 01:30 amNuance,you have 712 posts711 for salkdo you have any other interests?Not to be a pain but mixing it up could be fun!reminds me of those av123 automatonscome into the pool ...the water's fineMike
Nuance is OK. ... I know he operates a hair salon in Tokyo.
Quote from: Kokishin on 5 Sep 2009, 12:04 amNuance is OK. ... I know he operates a hair salon in Tokyo.There is a rumor that massage is also available.
