0 Members and 1 Guest are viewing this topic. Read 212260 times.
Can you stack the preamp and DAC on top of the amp? I know they have a picture like that on the AVA website but it just doesn't seem appropriate to put things close to your power amp like that.
Suggestions for tracks to use for speaker placement gladly accepted...
I believe that the issue with the DAC is not primarily heat but rather interference from the other components.
Congrats vintagebob!Jim tells me my STRTs are done and ready to ship. Unfortunately Fortunately, I an on vacation in Paris, so they will arrive in NYC shortly after me, early next week. Sheesh it is hard to type on this french keyboard. I look forward to hearing your thoughts.
If the DAC and the preamp are both solid state, they can stack in either order. If either one is tube or hybrid, that unit must be on top.Do not stack the small signal electronics directly on top of the big power amplifiers.You can stack the Insight 240 in the compact chassis on top of the solid state preamp and/or DAC.Regards,Frank Van Alstine
Do not stack the small signal electronics directly on top of the big power amplifiers.Regards,Frank Van Alstine
Quote from: avahifi on 13 Oct 2009, 09:42 pmDo not stack the small signal electronics directly on top of the big power amplifiers.Regards,Frank Van AlstineOopsie, need to find a new spot for the preamp.
