Owner Impressions, Delivery Times and Things to Do While You Wait
floresjc
Re: A Place to Salk While Waiting
« Reply #120 on: 12 Aug 2009, 03:45 pm »
Cables...check. I have some 10 gauge Blue Jeans cables at home hooked up to my Rockets. I need one more pair to hook up the HT3's, but those won't take very long.
vintagebob
« Reply #121 on: 12 Aug 2009, 04:23 pm »
I was actually thinking about all of the AVA equipment interconnects.  ; )
vintagebob
« Reply #122 on: 12 Aug 2009, 07:52 pm »
UPDATE
Jim contacted me today and said they were ready for final routing on my set of speakers.   :thumb:
He wanted to know if I wanted black front baffles on ALL of the speakers and I said yes.  That should match up nicely.
He also wanted to know if I wanted the grain on the oak sealed or not and I decided that I would have it sealed, which is what he does with most of the speakers.
My final set of GIK panels shipped today as well so everything is coming together nicely.  Yeah!  :green:
On a side note, I would like to thank everyone for participating in this thread.  It is fun to read about what everyone is doing to get ready and even more fun to see people getting their speakers.  I'll be there soon...
« Last Edit: 13 Sep 2009, 06:15 am by vintagebob »
jazzcat1
« Reply #123 on: 13 Aug 2009, 12:10 pm »
UPDATE
 :dance: That's great news! The long wait is almost over for you. I also got tracking info on my GIK order yesterday and expect to receive on Friday. Be busy this weekend upholstering 16 + panels.
mathgeek97
« Reply #124 on: 13 Aug 2009, 03:07 pm »
Blue Jeans Cable 10 guage, unfinished speaker wire is in the mail on the way to my house.  That should give me something to work on this weekend.  Surprisingly, the wife was mad I didn't ordered finished, terminated cables ("I'm not paying to fix your new speakers when you short something out!"  My response, "Don't worry, honey, the amp will catch fire, first...").   :green:
-Kevin @ 66 days and happy to wait for his one-of-a-kind, beautiful, custom HT2-TLs
vintagebob
« Reply #125 on: 13 Aug 2009, 03:10 pm »
New cables are fun!  Try to keep the fires down to a minimum.  ; )
vintagebob
« Reply #126 on: 13 Aug 2009, 05:55 pm »
Hey Nuance,
Can you describe to me how you are using your Parasound 2100 with your AVR?  Are you using the 2100 for your bass management?
Nuance
« Reply #127 on: 13 Aug 2009, 07:29 pm »
Hey Nuance,
Sure.
Yes, I am using the 2100 for bass management (only for music).  My speakers are connected via analogs from the amplifier to the "High Pass Outs" on the 2100.  If you don't connect via the high pass outs the crossover (static at 80Hz) won't work.  The other set of outputs is if you want to run your speakers full range.  I then run analogs from the "Bypass Inputs" (HT bypass) for both the subwoofer and speakers to my receiver's preouts.  Finally, I run one analog for each subwoofer from the 2100's "Subwoofer Outputs" to my BFD, then to a y-cable which plugs into the "Subwoofer Output" on the receiver.  This way the HT bypass is fully engaged, and I get the best of both worlds for music and movies.  The only caveat is a slightly different in-room bass response between my preamp and the Onkyo receiver.  What I do is EQ using the BFD and the Parasound 2100, then check to see what the response is like using the receiver.  Generally the Onkyo has more boost in below 30Hz (only a few dB), so it's like having a slight house curve for movies (which is great), but a flat response for music.  I still have a separate house curve for movies, but I hardly use it because of the naturally boosted low end the Onkyo produces.
So in short, the 2100 manages the bass response for music, but passes through to the Onkyo to allow the receiver to apply its bass management for movies.
I hope that all makes sense.
vintagebob
« Reply #128 on: 13 Aug 2009, 08:55 pm »
Hey Nuance,
Sure.
Yes, I think I got it.  It might be something interesting to look at after I get everything setup.  I tend to swap formats on a whim when I'm listening to music, jumping from CD to SACD to DVD-A and back to CD.  Using HDMI out of the OPPO directly to my SC-05 AVR works well with this scenario.
I think the Wolfson DACs in the SC-05 would be a little better than the Cirrus DACs (Stereo) in the OPPO?  There is so much to learn...
« Last Edit: 13 Aug 2009, 11:17 pm by vintagebob »
floresjc
« Reply #129 on: 14 Aug 2009, 07:36 am »
Nuance -
Have you ever used the MP3 input on the front of the 2100? I have an iPod loaded up with FLAC files, and I'm just wondering how well it works. The limitation is probably the iPod DAC.
Nuance
« Reply #130 on: 14 Aug 2009, 04:01 pm »
I have not yet tried it, but I'd be happy to check it your for ya later this weekend.
Yes, I too would imagine the ipod would be the limitation.  I've connected it via the headphone jack and a y-cable in the past (to a receiver) and it didn't sound very good.  We'll see, though.
vintagebob
« Reply #131 on: 14 Aug 2009, 04:28 pm »
You want something like this to get the audio out of the iPod dock connector instead of the earphone jack.  It makes a difference.  I use this in my car.
http://www.sik.com/din.php
jazzcat1
« Reply #132 on: 14 Aug 2009, 07:03 pm »
GIK tri-traps and fabric arrived today  :thumb: they look good; can't wait to get them home and put them in place. Hopefully the room will start to look like a listening room after this weekend.
vintagebob
« Reply #133 on: 14 Aug 2009, 07:33 pm »
Alright jazzcat1!  Have fun with that.  That MIGHT keep you out of trouble for awhile. ; )
rahimlee54
« Reply #134 on: 14 Aug 2009, 08:54 pm »
You can tell vintagebob is still waiting, he is a post machine :lol:.  Once he gets his speakers he will vanish  :P.
jazzcat1
« Reply #135 on: 14 Aug 2009, 09:04 pm »
Not until we see pics and at least a brief review! (I hope!  :wink:
vintagebob
« Reply #136 on: 14 Aug 2009, 09:23 pm »
LOL!  We'll see what happens.  I can't listen to my new speakers while I'm at work.   :whip:
oneinthepipe
  • Trainee
    • Salk Signature Sound/Audio by Van Alstine two-channel system
« Reply #137 on: 14 Aug 2009, 10:08 pm »
Nah.  We never vanish.  We just have stages.  1) Investigation (requires a lot of reading); 2) Analyzation (requires some questions); 3) Ordering (requires both pre-order and post-order announcements); 4) Waiting (posting varies on anxiety level of customer); 5) FedEx tracking (requires several posts); 6) They're Here (requires posts with photos); 7) They Sound Great (requires posts); 8 ) Existing owner (requires responses to categories 1 through 7 and any other Salk-related discussions); and 9 ) Former owner (same as No. 8 ).
vintagebob
« Reply #138 on: 18 Aug 2009, 02:29 pm »
Can someone give me the dimension of the height of the tweeter from the floor (w/plinth) for the HT2-TL?  I'm hoping to install some acoustic panels tonight and want to center the panel around the tweeter height.
Thanks in advance!
jazzcat1
« Reply #139 on: 18 Aug 2009, 02:46 pm »
Thanks in advance!
I asked Jim this question last week prior to ordering a loveseat. It is about 37". I asked Jim if having your ears exactly at tweeter level was as critical with ribbon tweets and he said not as critical as the dispersion is very good. I did use the 37" mark to center the panels on the wall.
