0 Members and 1 Guest are viewing this topic. Read 212132 times.
Whoa - those look fantastic!! I probably missed it, but did you put the prints onto the fabric yourself, or did GIK do it all? Wow - I need to do something like that. Truly cool!
I particularly like the sunset pic! Are the floors carpeted or hard?
Do the HT2-TL's have a rear port or are they sealed?
Thanks. I am trying to determine the minimum distance between rear of speaker and wall. 3 feet may be as far as I can go. There is a 242 absorption panel behind each speaker on the wall.
This is somewhat off topic but I was able to secure an ABX box and the assessory that allows dbt blind speaker testing. I know that it is a problem setting these things up but I would like to at least give it a try. My question is does anyone know where to get a large size speaker grill cloth such as what was secured for the Audioholics blind test. I have written Ton Andry but he has not yet responded.
All of my AVA gear arrived except the double 240/3, and the Telarc CD's are enroute. The HT3's from FedEx are a total loss, and its a long messy story, but I'm going to go with HT2-TL's instead (still very thrilled.) I chose to do a pair just like the dark curly walnut Jim has posted on the forum, adding a claro walnut baffle instead of the satin black. Its going to look great!
