0 Members and 1 Guest are viewing this topic. Read 67787 times.
Do you guys ever find that you end up playing your B200 OB louder without the filter?
MarkC:I will try a zobel. 6,8 Ohm + 47uF like in the Visaton designs. My EL34 triode Push Pull amp (soon to be KT88) will probably like that very much.
Can voice coil induction change with use ?
What does a flattened impedance do in terms of audible response? Is it just the impact on phase or does it affect amplitude too?
Is there any approved standard for Le measurements ?
And will voice coil inductance vary that much with frequency ?
