0 Members and 1 Guest are viewing this topic. Read 67839 times.
Newbie questions:What awg is appropriate for the inductor?What wattage is appropriate for the resistor?Thank you.EP
Something no one has mentioned is placement. For the perfectionists at heart, coils don't belong near the driver since it isn't shielded. The magnetic field can interfere with the coil, which also creates a magnetic field. If close proximity is unavoidable the 2 fields should be perpendicular to each other to cause the least interference.
Quote from: JohninCR on 27 Sep 2006, 02:49 amSomething no one has mentioned is placement. For the perfectionists at heart, coils don't belong near the driver since it isn't shielded. The magnetic field can interfere with the coil, which also creates a magnetic field. If close proximity is unavoidable the 2 fields should be perpendicular to each other to cause the least interference.I was also considering this very thing. More for convenience though.Is is appropriate to wire the parallel bundle at the + terminal of the amp? I assume this is ok because the bundle is still in series, only at the other end of the speaker wire. Can this cause similar interference with the amp?Thanks again!
