0 Members and 1 Guest are viewing this topic. Read 67930 times.
What do you think I should do?
I have to agree with MJK, I used to think the B200 didn't need a filter at all. I tried one and found it evened thing out, but at a price of sensitivity. So the driver sounded kind of closed, but this weekend I got off the DIY amp thing and bought a Marantz PM7001. Having 70w compared to 10w make a big difference in my setup. The drivers don't sound as open, as without the filter, but the filter is much more livable and enjoyable.Only thing to do is experiment.
I know of quite a few, myself included, that have tweaked it without a filter and with bass augmentation and are happy/satisfied with it.Have you tried dampening the back of the driver?Lin
QuoteWhat do you think I should do?Pick the configuration you like better. It does not matter what anybody else thinks, writes, has used in their system ....... Live with it for a while. Change the set-up if it becomes less than what you ultimately want from the speakers. Stop considering what others say or think. Be open to changes that you might like better, it is a great adventure. Enjoy and have fun.
The Behringer surprised me, it is running circles around the 8 unit 1543 NOS DAC I used previously, producing a very natural sound. /Erling
Some speaker reviewers make a point of speakers sounding very good in another room (indirect listening) in their reviews. These are about the silliest remarks ever done. You can all very easy prove that case by listening to any simple Transistor Radio from a distance and it will sound better than when you are directly in front of it. Well, my B200 sound very good both up front and from a distance./Erling
The OB is so much more lush and organic ....
QuoteThe OB is so much more lush and organic ....Sorry for the OT post. I keep seeing the descriptive word "organic" applied to the sound of equipment. What does "organic" mean in terms of audio equipment performance or sound?
