0 Members and 1 Guest are viewing this topic. Read 67786 times.
Hi everybody,My name is Rafal. I'm getting ready to build B200OBs and I have just finished a Charlize amp to drive them. I also ordered .68mH||6.8 ohm components for a notch filter based on your findings. I was wondering, will Charlize be enough to drive my B200s with a notch filter since it really only has 10 useful watts? What will be the resulting sensitivity (the b200s themselves start off with 96dB)?I really hope I won't have to get a different amp.Cheers,Rafal
-> RafalMy Charilze drives B200 with 1mH||6.8R filter without any problems. Charilze is digital amp and this kind of amps don't have any problems driving low impedance speakers, so don't be affraid. Charlize and B200 really cooperate great.
-> RafalWhere are you from? Are you polish? Couse your first name looks like typical polish name. I live in Warsaw, so ...
"wybrzmienie"
Nice to find countryman on foreign forum . IMHO Monica is really good amp for high efficiency speakers. Good means: dynamic, with good bass, detailed and transparent, but ...compared to good OTL tube it lacks air, space around instruments, full timbre and mostly something witch I don't know the word in english, in polish it's "wybrzmienie" ( sound after main tone).
Harmonics, maybe?
