0 Members and 1 Guest are viewing this topic. Read 67868 times.
I don't imagine most of us have measured the actual response of what they are getting from their implementation in their room. I'm not technically equipped as such and so I depend on my ears, which is fine because at the end of the day that's the final test. About 4 months ago Don Nodiak posted the results of what he achieved in his room without BSC, EQ etc. With only one B200 per baffle and nothing else he recorded a very flat response of +/- 2.5db between 250Hz and 8K. For the record, here is his post...http://www.audiocircle.com/index.php?topic=19253.msg249958#msg249958I think this is worth looking at again just to prove if nothing at all, that we shouldn't get too hung up on Visaton's FR graph. As with any speaker the end result will depend on many factors. The B200 is an amazing driver and I have yet to hear ANYTHING at ANY PRICE that sounds even half as good as the B200 in OB. Best of all it is a true point source that doesn't depend on multiple drivers, crossovers and all the other compromises that are so prevalent in modern speaker design.John
Hey Vinnie, Are you bringing any of this stuff to the RMAF next month?
I hate to say it, but is there something wrong with the measurement? Assuming the guy is not using digital EQ, there is no way the responds drops starting from 1K and -5dB at 8k. My measurement is exactly the opposite, is the guy measure 30 degree off-axis? Also, even with -5dB roll-off at 125hz, this looks like a dream compare to what I have for my B200. I am not sure we are even talking about the same driver.But I would concur that the B200 is an excellent driver, and very easy to get great sound. But so far, I don't think it can replace my 2-way scanspeak just yet.
I don't think my 2-way can be unseated, it gives a different sound compare to an OB. The imaging is more sharp and believe it or not, better soundstage than b200.
