He said : "long pulses" - 1.4112 MHzTwo posts later he said: "there are also short pulses, at 2.822 MHz."So, what is your point here?
Pat,I have a 8' RCA/RCA so-called digital cable (Blue Jeans LC-1) which I inserted in place of a much shorter cable and did notice, I think, some improvement. Certainly My DAC does have a BNC input but my SB3 doesn't have a BNC output. Would I have better SQ if I changed one RCA for a BNC and used a RCA to BNC adapter on the other? Also is there an optimum length or is longer always better.Thanks,Roy
All 3 components of the chain contribute reflections: TX end, RX end, and the cable.On a typical system, with RCAs and poor control of output Z (especially over a wide frequency range), you can easily get 20% reflection from either end. If 20% bounces back from the RX end, and 20% of that bounces back from the TX end as it is re-reflected forward, you are down to 4% total energy ending up at the RX end as an unwanted signal. If you can reduce the TX end's contribution to only 5%, then you will only have 1% unwanted energy arriving at the RX end.If you can get both ends to reflect only about 4-5% of the signal, you can see how you can get far below 1% total reflection.(All this ignores the cable; we shall assume it is matched fairly closely.)Since I have done RF design for a living, I can get below 1% on both ends. You need good test equipment to be able to do this.Some of you may recall from the data that I posted a few years back that some of my stuff has 4% or so of reflections. That is true, but I am measuring out to over 1 GHz. Over 10 times the BW of the SPDIF signal that you will ever encounter. When you reduce the BW, it drops to 1%.Hope this helps to clarify things.Pat
Here is what attenuators do:1.) They attenuate the incident signal, by the amount of the pad.
So, I guess that means that RCA/BNC should reduce reflections more than RCA/RCA therefore that is good.
Cable length, hmmm...? Maybe the little digital packets are like a steam that likes a clear, unobstructed channel.When you implement a connector, it's like a small dam that introduces turbulence(reflections) but eventually they smooth over a distance. So a longer cable smooths out the reflections more than a short one. Therefore, the more compromised your connectors; the longer your cable should be.-Roy
Anyone interested in the relationship between SNR, slew rate and jitter should look here:-http://pdfserv.maxim-ic.com/en/an/AN3631.pdf
The bottom image shows jitter vs. noise for a sinewave (zero crossing).
(not least the idea that characteristic impedance can be measured using a DMM).
RF attenuators ... cause more harm than good
You call it wriggling.I call it feeding a troll.Pat
If you read posts #4 thru #9 it's quite clear that he believes the fundamental bitrate is 44100*32 and that what he is referring to when he talks about the 'frequency' of the long pulses is the pulse repetition rate.
I have never suggested this. When are you going to understand the difference between characteristic impedance and terminating impedance?w
We had to go to considerable lengths with very fast rise times, a very expensive oscilloscope and long, long cables for a university lab demonstration of reflection in digital systems, so I don't believe you've got plots. Not in an SPDIF system.
