0 Members and 1 Guest are viewing this topic. Read 52971 times.
Yes, it should show a negative going spike, but as you have deduced, whatever is after it is causing that spike. My guess is that this unit has the SPDIF transformer that everyone (well, almost everyone) thinks they must use. Guess I should take the lid off, and verify.
(Stuck at home today............ice everywhere. So, something to do.)
The small downward step is indeed the cable. Its impedance is a bit less than the other piece.
Also, just to be clear, you are suggesting that the best solution shown above is the fast driver, long cable and proper built in pad right? I see the differences, but wasn't 100% clear which you thought was better. It seemed like the slower driver and 10db of attentuation resulted in an OK outcome too.
I'd love to know what the draw backs to using I2S are (whatever cable format) too? I do recall reading that sending the signal requires really fast drivers. Is this really difficult to design? Are reflections worse?
here it is, the response of a video amp, with feedback, when "pinged" with a TDR. That is, the same way like Pat has done it here with that Dac.(For those who don't have access to the Diyhifi site - which is a pity )It's a little bit different, because this TDR shot contains also the effect of the saturated amplifier.Without that it would "relax" back all the way to the baseline.
Well I don't know what the big deal many audiophiles have against 3m digital cables. It seems that could only help placement of gear.
(Translation: if the guy who designed your USB-SPDIF thingie copies the TI data sheet, you should expect problems. Because the data sheet is wrong, and he/she/they didn't figure that out. Obvious, to some of us old farts.)Pat
What happens is: in theory, the C.U.T. above should be like the input is terminated in 50ohm. The 50ohm resistance is connected to a virtual ground.And it is, once all transitions are settled down - that is, the output had reached it's final value. But it takes time, the "settling time" of the amplifier, to reach this equilibrium.
During this transition, as the current starts to flow slowly, we will see an input impedance slowly decreasing from ~infinite (R1+R2+stray inductance)to the value in equilibrium, that is 50ohm. This may look like an inductive spike, but is "output settling reflected".
I think what can help to distinguish between the two is that it would take a real big stray input inductance in the circuit, to reach that monster timing in the shot of Pat: tau is something like 20 nseconds?
In my case, tau is ~ 7nsec, and that is a 1.5 Ghz GBW amplifier.
Ok, finally I did get what your objection was about:
