The only reason that you see that hump in JosephK's picture is because it's done on a TDR. TDRs have a very fast rise time, that's how they achieve their resolution. The TDR's rise time exceeds even that of the video amplifier, which has a respectable slew rate. Consequently the voltage at the input node rises faster than the amplifier can compensate by feeding back through R2.If, however, the video amplifier were hit by the ~6nS typical rise time of an HCMOS chip, this hump would be barely visible, if at all, because the amplifier would be able to maintain the voltage at the inverting input close to 0V. N'est ce pas?Trivially, the stray inductance in the feedback loop is insignificantwOui, c'est vrai.
Please keep the topic technical
You need to slow down and read everything again..And, as an added bonus, you'd probably see that Joseph's setup actually caused a 1 nSec total risetime.
The TDR sends a ~ 90psec rise time, 400mV magnitude step signal
the ... dialog is providing many of us with useful learning material.
There is no question of this being an 'active' reflection, it's shape is entirely characteristic of a passive inductive termination, if it were active one would expect to see a change in level on the RHS when the output has settled.
Rather than mislead readers it is only fair to point out that I have made a mistake here...
My apologies for any confusion caused.w
how long does it take for light to travel .0001 inch?..
Can anyone explain to me how this is germane.
Twice now I've pointed out to you the errors you have made in your own words.
Twice you have attempted to to ignore it and engaged in attempts to browbeat me and wow the audience.
My engagement with you is at an end.
In the meantime, here are a few extracts from SPDIF receiver datasheets from Cirrus, AKM, Wolfson, and Texas (SRC4392).
AND, that 1 nSec is the EXACT same signal slew that Pat CLEARLY stated.
This is with a very fast source. It has a rise time, around 0.8 pSec. The problem is...........
If you are going to argue theory with someone who does it for a living at levels 3 orders of magnitude beyond any experience you could possibly have, you need to get your ducks in a row.
If you actually looked at the scope pic, it's 1 nSec.
Scopes have rise times too.w
What's this. if it's not browbeating and trying to wow the audience?w
"read what I wrote""No, you read what I wrote"...
my intentional error
