0 Members and 1 Guest are viewing this topic. Read 92098 times.
still in my main system:- vmps larger subs - 1995- melos ma333r preamp - 1999- electrocompaniet amps (first mains amps, now sub amps) - 1995- art di/o dac - 2000- pentagon ps-3 fono stage - 1999- oracle delphi turntable - 1999- onix bwd-1/soap-2 fm tuna (occasionally) - 1995- the marchand xm9-LL lasted from 1995 until end of 2007, when replaced by deqx.ymmv,doug s.,must not be an audiophile...
It must measure really well, eh Doug?
Doug, great to hear that you have stuck with/love those equipment for this long. I hope to attain that kind of love so I can enjoy music and not components!
what are the nighthawk specs?
Seriously though, think of it, do you have any current equipment that you've had for 10 plus years? If not, the battery is not an issue. I don't know of any audiophile that has a component for 10+ years.Tuan
naw....yust a yoke.....spillover from the other "wanker" thread....predictive nature of good measurements for good sound....you had to be there to get it, I guess. Wait, you were!
I have been considering either the Nova or Nighthawk phono stages-they are similar in many ways. I was wondering JTSnead how you would compare these two phono stages sonically.
It's in 6 increments. Looks like the increments are just shy of 6dB.
No noise here either and I have mine directly on top of my CD player. I don't know if this is the correct way of adjusting the gain but I set mine to be roughly the same volume as my CD player when I switch back and forth between CD and phono. .8mV cartridge and third lowest (11 o'clock) gain setting.
Interesting that some of you guys are having noise issues with the Nighthawk. Mine is dead quiet like a tomb regardless of where I site it.I'm using a HOMC (2.8 mV) so I use the 2nd lowest gain setting. I feel I might be maybe just a touch short, but when I try to go one click higher (more gain) it seems like a very big jump. Was hoping other members could comment on their experiences.I know the bottom one is 40 db and the top one is 74 db. Ray, could you chime in here and tell us what the actual gain figures are for the in-between settings?Thanks!John
The lowest gain setting, if it is 40 db, should be almost ideal for your cartridge with an output of 2.8 mV so you might want to try that. Typically, proper gain matching with cartidge/phono preamp will result in running a fair bit higher on the volume pot on your line level preamp or integrated than when playing CD. It would be a bit odd if you did not unless you attenuated the CD input to try and match levels. I could be wrong but I think you'll find that your sound quality will improve and the overall sound character will be much more "relaxed" and a bit less strident/aggressive if you drop down to the 40 db gain setting. As I say, though, you will be running higher on the volume pot with analog than you will be with your digital setup. Perhaps worth a try.
<snip>I did not know it was normal to be running the line stage volume pot more open for vinyl than compared to digital. I thought if you had appropriate phono gain the two sources would be real close to level matched at any volume pot setting.
