0 Members and 1 Guest are viewing this topic. Read 92029 times.
Thanks for the informative reply, Blake. But using your logic begs the following question. If the lowest (40db) gain setting is appropriate for my 2.8 mV cartridge, what would much higher outputs use....like those in the 5.0 to 6.0 range?At 9 db my line stage gain is just a touch on the low side. My Vista phono section gain is fixed at 40 db. I definitely use more of the volume pot with it compared to CD. For most of my listening it is fine, but when I crank the vinyl tunes a bit it kindof runs out of steam. That is why with the NH I find the setting right above 40 db to be close to ideal. I assume it is about 47 db.I am always interested in improving my sound so I will try the NH set to 40 db instead. Thanks for the tip. I did not know it was normal to be running the line stage volume pot more open for vinyl than compared to digital.I thought if you had appropriate phono gain the two sources would be real close to level matched at any volume pot setting.
I have tried everything I can think of. Cartridge is Dynavector 20X-H. Output is 2.8 mV and mfr rec'd load is "greater than 1k". It sounds best at 47k. When I goto 1k load the top gets rolled off, and continues to get worse with more loading.The lowest NH gain setting (40 db) seems about right for me. One higher (47 db?) is also OK......probably a bit too much since it keeps me real low on the volume pot. The next one up (54 db?) is definitely too high.My Vista phono section is set for 47k and 40db.....exactly how I use the NH.Next up: This week I will borrow a cartridge (Dynavector 17D2) from a buddy to see if that gels any better. Maybe for some odd reason the 'hawk just doesn't wanna play nice with my 20X-H? Any other 20X-H users out there?I also have a Clearaudio Virtuoso Wood in the drawer. That would be interesting since it requires the same 47k and 40 db settings. Cantilever is a bit bent so I'd rather not, but I'll do so if I hafta....in the interest of science.
I get great bass with my NH. Very tight, focused, coherent and with great weight and slam.I will be very interested when/if you figure out what is going on with the interaction in your system.Have you tried adjusting the load?
Is it possible there is something defective in your phono preamp that presents itself in certain loads/gains but not in others? Maybe your friends cart wasn't dialed in using the malfunction section? I'm not technically savy, but I'm trying to think of something...
I don't want to pile on, but I hear the same as tomjtx. I'm curious as to what could be causing this? I currently use the Low Output Benz Glider. Maybe it's the high output cart you are using? Hopefully Ray will chime in. Good Luck.. Gary
