0 Members and 2 Guests are viewing this topic. Read 1200692 times.
Larry, I like some of those, but isn't that site selling wholesale? Can you order one or two switches?
Hey guys, I'm sure glad I found this thread. I recently bought Tom's SDS-224 kit and have a couple questions. For some reason he seems to be hesitant to answer my emails regarding much needed product information. Hopefully you guys can shed some light on the situation.Question 1. Looking at his transformer wiring diagram all the leads from the transformer are accounted for except for one lead which is purple. I can't find anywhere on his website that addresses this wire. I've heard from another person that it may be a chassis ground. Problem 1, I have an all wooden chassis. What do I do with this lead in this case?Question 2. I have a very nice preamp, so is it possible to just not hook up the gain pots? Or are they required to complete a circuit of some sorts? In my opinion it'd be best to do all the volume attenuation with my preamp instead, but if I'm wrong and it's a necessity that these are connected, then it is what it is. I also have no idea how to wire these, as my kit came with zero paperwork besides for the transformer wiring diagram.Question 3. Is there a certain type of LED's to use? It looks like it uses 4 molex connectors for external LED's. I don't mind using these, but could use an idea of exactly what I need these to be. Also, are these required to be used? Ideally I'd like to not have crazy bright LED's, and if again, I could just not hook them up I think it'd be the best solution.I look forward to you guys' input.Thanks,StevenZ
Hey guys, I'm sure glad I found this thread...Question 2. I have a very nice preamp, so is it possible to just not hook up the gain pots? Or are they required to complete a circuit of some sorts? In my opinion it'd be best to do all the volume attenuation with my preamp instead, but if I'm wrong and it's a necessity that these are connected, then it is what it is. I also have no idea how to wire these, as my kit came with zero paperwork besides for the transformer wiring diagram.I look forward to you guys' input.Thanks,StevenZ
Thanks for the help guys. I got everything soldered up and ready to throw in the chassis. Regarding the purple wire, I just noticed that there is a standoff on the amplifier board that has an arrow pointing to it with the print "Chassis Ground" written near it. If the purple wire is indeed a chassis ground and this has chassis ground written on it, does it not make sense to connect the purple wire to this standoff? I'm very excited to get this amp up and running. You guys are great, and I can tell this forum is a great place to learn and meet new people with the same passion.Thanks!
I am thinking about getting the SDS-470 for a pair of Dayton RS265HF sealed subs but need to know if they come with pots or are they fixed? I was looking at the picture on the previous page and it looked like they would use the pots. I need the pots to match the levels with my SDS-254 and tubed preamp and active cross over. I tried one 254 on the subs but they dont seem to have enough power and got pretty warm to the touch very quickly. Im running them with two Dayton SA240s and they go deeper and a lot louder but dont sound nearly as good as the SDS254 did. I think these subs are just very power hungry and need alot of head room. I also think the SDS-470 would probably be just right. Any one else using these subs?
Does the SDS-470 come with the transformer in kit form, I didnt see it mentioned on web site only heavy duty P/S? What size is it or should I order if it isnt part of the kit? Thanks
Steven welcome, that purple wire is a secondary and just gets taped off.
The pots have to be connected, you will find diagrams a few pages back.
