0 Members and 9 Guests are viewing this topic. Read 1216619 times.
http://www.audiocircle.com/index.php?topic=18443.0Or use the search function and type in "Felix". There are many threads on them.
Thank you Jason. Appears to be a longish thread. Will read it at leisure. Subscribed to it.
Firedog and Corndog71...I notice on the pics of both your amps there are no gain pots... are these set for a fixed gain? It's hard to tell from the pics if you have a resistor in the molex connector where the pots usually attach.Thanks... just wondering since I've got the SDS-450 on the way and I am planning to gain match it to my DAC/preamp.
"Class D Audio's amps have a panoramic sound stage, not a forward one. Portions of some recordings will sound more recessed as a result. It sounds like you're hearing the parameters of the amp's sound stage to me. "
Maybe I'm not explaining what I'm hearing well. I just listened to a Don Cherry (jazz quartet) album and the Neil Young "Live at Fillmore" album. On both the cymbals sound fine - just like I'd expect. But on SOME albums, it seems like the cymbals are farther down in the mix, not quite as loud, or farther away than I'm used to. That's why I think what Blair said may be right - the presentation of this amp is different to what I'm used to, and therefore on some albums - those with significantly more depth in the soundstage - this amp recreates that and the cymbals sound different to me.
Built my SDS254 a few weeks ago and have been enjoying it for the most part. It replaced an old Adcom GFA 545II. I use a Melos SHA-1 Tube Headphone/Line stage for the pre-amp. I am hoping some one can tell me what size resistors in place of volume pots to use on amp board. I had gain issues with the Adcom and 1/4 turn was almost full volume? I have seen the chart but not sure what size resistor? My pre-amp specs are Line Gain 19 db, Input Impedance 100k Ohm, Out Impedance 0.5 volt. Thank for any help you can provide.
