0 Members and 9 Guests are viewing this topic. Read 1216619 times.
I even went bare-minimum on my design: combined fuse+IEC, no power switch, two XLR inputs and four speaker binding posts.Hey Matt, are you running a fully balance system? There is no mention of SE rca inputs. If the SDS-470 sounds no different than a QSC pro amp, I doubt this thread would be almost 150 pages. Not sure what's holding it back.
Glad you're having fun.
Matt I do not feel you need to make excuses for your comments about ClassD Audio products. I got blasted for not jumping on the band wagon. My ClassD amp has been junked and I am using the PS for something else.
No offense Pelliot, but why is it necessary to beat a dead horse?You have notoriously difficult speakers to drive and you bought the wrong amp to drive those speakers.
Either call or email Tom at Class D Audio about the problem. I'm not sure what's going on. I don't recall reading about that particular issue. Let us know the outcome. Thanks.
all of a sudden I notice the right channel cutting in and out. Just the right channel, so I walk up, crack the top off the amp and notice that the right channel is dropping out and the yellow LED's are lighting up, then switching back to blue. I touch the heat sink to see if maybe it's overheating, dead cold.
Rajesh, I won't jump to conclusions. Anything could be the problem.
What I'll do is run double wiring from the PS to the Amp board to eliminate the possibility that there's any bottle-necking going on regarding current supply.
I talked with Tom earlier today and he said that he won't know without looking at the actual unit. He wants me to send it back to him next week so he can evaluate it in person. He guaranteed me that everything will get worked out. His reply was very quick and I feel confident he will take care of the situation one way or another.
I finally completed my SDS-470 kit build this past weekend. I thought I'd post my initial impressions.First: on the first test, I powered it on, but got no sound. I noticed the on-board LEDs indicated "Left Off" and "Right Off". The power supply lights were on. I used my DMM, and verified that I had DC going to the amp board. Nothing changed on the preamp side, and the music was playing. I was about to come here to ask for help when I noticed the little built-in "on/off" switch on the side/bottom of the amp board! I switched it on, and I got music! Classic ID-10-T error on my part. Anyway, as for the sound quality discussion (what everyone is probably most interested in). On the very first listen, as I mentioned briefly above, I really couldn't tell much difference between the SDS470 and the RMX2450. On a few rare occasions, I thought I've heard a little bit of sibilance... but lately, I haven't heard that. Not sure if I imagined it or not. Also: depending on the input gain setting of the pots, I can hear a very faint hiss coming from the speakers when my ears are a few inches away or less (and there is no music playing). Adjusting the gain fixes this though.I don't know if my ears are getting used to the unit, or it's being "broken in" (a concept I'm not sure I really believe in anyway), but last night I felt like the amp had a little different "character" from the QSC. Is it better? Maybe. It does sound great, there is no doubt about that. I'm just not sure if the difference is all in my head or not. It's too annoying to keep switching between the two amps, so I try to just go from memory (I'll be the first to admit I have an awful memory ). But last night, I thought I was experiencing a bit of what I've read so much about on this thread, particularly increased instrument separation and a bigger soundstage.Ultimately, I just need to spend more time with it. But so far so good. Next step I believe is to give a SMPS a try. If that proves successful, then I might move forward with the monoblock idea. At a minimum, I would spring for a professionally machined and finished enclosure.I'll try to find some time to post pics.
