0 Members and 4 Guests are viewing this topic. Read 1216673 times.
Mine is still making the sound on shut off and a small pop when turned on. I hope it doesnt cause any damage to the amp, but the level of the sound is so low I just ignore it now.
I finally put this bad boy together (CDA-254L). I notice most of you put your transformer with the wires on the bottom side, but it seems that the wires would be bearing all the weight. Is it 'supposed' to be at the bottom?
I finally put this bad boy together (CDA-254L). I notice most of you put your transformer with the wires on the bottom side, but it seems that the wires would be bearing all the weight. Is it 'supposed' to be at the bottom?Preamp: IRD PuristSource: SqueezeboxI played it for about 4 hours tonight. Right off the bat it was grainy, but it quickly smoothed out. After about an hour, the graininess went away, now it is all very smooth.. By the end of the session, the it sounded great! I cant wait to break this in some more.
Thought I'd post my project. I'm bi-amping a pair of Klipshorns, and wanted to see if I could include everything in one case. This is a temporary setup, but so far so good. Includes an SDS-480 kit, and Marchand electronic crossovers (24db slope). Initially, had issues with Marchand's, in that they needed to be powered up BEFORE the amps, or I got a very loud transient POP. Solution was to use my old Monster Power Center. The amp power supply is plugged into a delayed switch outlet, and the Marchand PS into an immediate switch outlet. Now, the amps power on a few seconds after the Marchand PS, and power off a few seconds after the Marchand PS is powered off. I will not need power switches on the enclosure.
Nice crossovers. How much did they charge for each crossover? Any reason for not choosing a separate 1U or 2U case for them? I can see myself heading down this path. But would need another amp and different speakers before then. Also, are you using some sort of mic to measure the frequency response of your speakers?Philippe
Hi,Here below some pics of my SDS-470 amp that Tom made for me.Thx for your feedback.
That's a lot of powerful amplifiers for one power supply. What are you driving with it?
your amp has more than enough power for music or home theater. This controversy over transformers and power supplies has been going on for years. This would be true if you were running a constant sine wave through all 6 channels, but music and movies is not a constant sine wave. The amps will actually only bee using about 1/8 power for this. If this amp had a 3KW power supply, it would be huge and just allot of wasted space and power. The only time the amp would need such a large power supply is for bench power testing… something only a manufacture would do. Also, our amplifiers are about 92% efficient and draw much less power form the wall than other types of amplifiers. I think when you listen to your amp, you’ll find you have more than enough power.
I trust him. He will never build and sell undersized power amps...
Like he said....it will be good for typical home use. You must tell Tom what you are doing with the amp.If you told him you needed power for large subwoofers, each SDS-470 would get it's own transformer and power supply.
On the power consumption front, I'm using an AC Watt meter (Kill-A-Watt). The SDS470 seems to pull about 22 Watts, both at idle (no music) and typical listening levels using the standard kit linear power supply. I haven't really cranked it up yet. Compared to the QSC, which pulled 40--60 Watts between idle and music. A definite improvement in power usage. As I suggested above, I'd like to get a switch-mode power supply (SMPS) to see if I can further reduce idle power consumption.
When using my DMM to check DC voltage on the linear power supply, I accidentally got the probes too close together and generated a nice arc!
Hi,I made the same remark to Tom.I successfuly drove with it Elac and Wislon Benesh speakers.Here below what he answered to me.I trust him. He will never build and sell undersized power amps... Since I receive this amp I had the opportunity to test it on Wilson Benesh Vertex speakers (outstanding product, by the way!!).My ClassDaudio amp worked better than Sugden MPA-4 on Vertex and no lack of power (even at high volume).
