0 Members and 3 Guests are viewing this topic. Read 1216941 times.
I am about to order a Par Metal Case and I have a couple of questions about it. Will the 16x12x4" case have enough height to fit the 400VA power transformer or will I need to go with a 5" tall case?
1. I have the 250 watt version SDS 258. About 8 months.I've used 2 different power supplies and there is still an erratic noise, maybe every 1-3 seconds, low level around 200-500hz. It's been doing this since I got it.Anybody else have this?
2. Setting gain with Vishay resistors makes this a great bargain amp. Ordinary resistors=ordinary sound.
3. I remounted the output inductors on the bottom of the board, same holes. Cleaner, clearer sound, not quite as large improvement as the Vishays. I think less interference for the magnetic/electric field they radiate axially. No metal caps nearby.
No, have never experienced this noise. But am still using the CDA-254L kit with supplied Antek torroid. No mods were done to it. Maybe you can have your amp checked by classdaudio?Interesting. I wonder if they use the same resistors on the non-balanced versions. Which model Vishay resistors did you use? Based on the pic I'm guessing that you mounted the amp board on its edge? Another cool idea on the inductors. If I did that mod, then I'd probably keep the same mounting scheme but use longer standoffs to raise it up.
I am building a new system from the ground up with some brand new Magnepan 1.7s. I've always been a headphone guy, so this is my first "real" system. My listening room is pretty small (11'x16' or so), so I don't need tons of power for loudness, but I do know the maggies love power so I want as much as possible even though I'll be listening at low to medium levels. ... I have read through this whole thread and I see there are a few other maggie owners. Any recommendations for a particular version? My first option is the SDS-470. I was also thinking of the SDS-1000 kit. Is that overkill? And the fallback, basic choice is the SDS0254.
