0 Members and 4 Guests are viewing this topic. Read 1216684 times.
6amp? that seems small. I also have my dodd buffer and dac on the same supply and they both use 2a fuses.
I agree with Corndog71 in regards to the sound of the Class D Audio SDS amps. I have a SDS-470 and am impressed with the full tonal range. It is neutral to slightly warm. I paid $600 for an assembled unit (switchable RCA & XLR) and I think you will be over $1k and probably closer to $2K to reach this level of performance.
I rebuilt my SDS-470 with a switch-mode power supply. The smaller power supply allowed me to use a much smaller case; I found one on ebay that had most of the holes I needed already drilled, saving me time.
I rebuilt my SDS-470 with a switch-mode power supply. The smaller power supply allowed me Even when I first turn the unit on, there's a faint "burning" smell that comes out the top. So something is definitely cooking, and when it gets to a point, it starts affecting on of the channels.
To Roymail:I am in france..i use a sds470 amp, and have been continuously improving the sound thanks to mods to the speaker cables and interconnects.Two days ago,i tried a new cable for the treble section of my Duntech Prince speakers.The (-) is made in flat siltech wire, but i worked only on the (+) wire.I tested for the (+) wire going to the treble section in bi -cabling, a wire made as follows:-one thread in pure silver, diameter 0,6 mm, teflon coated-one thread in litz copper wire, 8X 0,28mm vernish coated-one thread in litz copper wire, 25X 0,05mm vernish coatedThe result is absolutely incredible: the cymbals sound like if in the room, the percussions are very fast, very present,the high treble has got a lot of "air", the dynamic power is improved.This is confirming that the sds 470 tends to be a little bit "shy" in the extreme treble area, but if the interconnect to the amp is chosen correctly, and if the speaker cable favourizes the extension of extreme treble ,the "shy" character disappears completely and this amp sound incredibly fast and clear, i donot see any amp at any price which could perform undisputedly better.imho.
But about my "for a while" comment: after I listened to music for a little while, my wife wanted to watch a movie. Towards the end of the movie, we started hearing this "pss hss pss psss" kind of intermittent soft-static sound. We paused the movie, and it persisted. There was only a couple minutes left of the movie, so we lived with it. When the movie ended, we noticed that not only was there the pulsing hiss-sound, but there was an overall static-sounding white noise. This is all from one speaker.It was late, so we shut everything down and went to bed. Today I fired it up again, and initially, again, it sounded great. I suspected that since the problem showed up after about two hours last night, it must be a heat problem. So I put a blanket over the amp, and sure enough, after a song, it started making the sound. I took the blanked it off, and it went away, but then came back again with a few seconds. I could blow on the top of the amp (it's not shown in the picture, but the top plate fore the chassis has some vent holes) and make the hissing stop momentarily.
To Roymail:I am in france..i use a sds470 amp, and have been continuously improving the sound thanks to mods to the speaker cables and interconnects.This is confirming that the sds 470 tends to be a little bit "shy" in the extreme treble area, but if the interconnect to the amp is chosen correctly, and if the speaker cable favourizes the extension of extreme treble ,the "shy" character disappears completely and this amp sound incredibly fast and clear, i donot see any amp at any price which could perform undisputedly better.imho.
Ainsley, I know you will give it a try out. So please report back your findings. The heatsink looks like the real deal. Great price.
