0 Members and 3 Guests are viewing this topic. Read 1216941 times.
What gauge wire runs between the power supply board and amp board?
I got one of those infared laser thermometers and took some readings... What I found was that the PCB itself was hottest, moreso on the right side than the left. The PCB on the right side, near the output area was 150 degrees Celsius, but the left side was only 50 degrees Celsius. I asked Tom about this, but all he said was "If you're using a laser type thermometer you will get this kind of reading." I didn't want to bug him and ask for an elaboration... maybe someone on this thread can do that? I know these laser infared heat guns aren't the most accurate, but shouldn't a 3x difference from one side to the other be indicative of something?
The only other quirk is the SMPS800R makes a slight humming/buzzing sound. Generally it's quiet enough that it can only be heard when my ears are within about a foot of the unit. But sometimes it's a bit louder and sometimes quieter. I just asked Cristi about this over on the diyaudio forums.
So, all my issues are solved except for this heat issue. Note that if I switch inputs and/or outputs, it's still the right-channel side that consistently reads two to three times hotter than the left-channel. Assuming my thermometer is at least in the right ballpark, then I worry that the life of my SDS-470 could be dramatically shortened from running at these temperatures.
Does anyone know what Tom means by his statement, If you're using a laser type thermometer you will get this kind of reading? I've since pushed for an elaboration, but haven't received any response.As long as I don't wrap the unit in blankets, I don't have any audio issues. But the unit still runs quite hot, according to my thermometer. The other day, everything sounded fine, but I pulled the cover and took some readings. One of the big capacitors on the right output side read 160 degrees Celsius. But the left side was only 60 degrees.His reply: The buzzing noise comes when the smps works in burst mode or discontinuous mode. this is a pulse-skipping operation mode implemented to reduce power consumption at no load or very low load. it starts to operate normal as soon as the load reaches 50-70mA on each rail or ~3-5W power. that's below most of the amplifier quiescent current, but some amps could draw less than that if they are muted.So, all my issues are solved except for this heat issue. Note that if I switch inputs and/or outputs, it's still the right-channel side that consistently reads two to three times hotter than the left-channel. Assuming my thermometer is at least in the right ballpark, then I worry that the life of my SDS-470 could be dramatically shortened from running at these temperatures.
