0 Members and 9 Guests are viewing this topic. Read 1216619 times.
Thanks Firedog, I was shocked that this works. For some reason I thought the volume control on the SB Touch degraded sound quality below 80%? Maybe thats just a myth?
Does this mean I should run my SB volume at 100%?steve k
Make sure to set your gain pots at a point at or just above the maximum volume you would listen at if the SB was turn up to 100%.
You lost me here man, can you explain?
You lost me here man, can you explain? BTW: Has anyone used the Dodd buffer with these amps? Does it work well and do the amps get loud without the buffer introducing gain?
1 kOhm
Mike, Not sure if it would work without a resister, but the resister is also what is determining the gain of the amp. Very worthwhile for a number of reasons (noise floor and greater finetuning of the volume control being the biggies for me).
So you have completely bypassed the pots with no resister at all? Good to know that can work in appropriate set ups. Duly noted.
If you use a pre to control volume then yes. Digital volume control does degrade the quality.
Getting Excited, Tom is testing my amp before shipment... Think the 470 will have any trouble man handling my Gallos? Tom thinks the amp will smack em around and have them begging for more... Cant wait! Now, to preamp or not to preamp, that is the question!
