0 Members and 4 Guests are viewing this topic. Read 1216531 times.
Greetings, I've recently just ordered a couple of ClassDAudio amps, was wondering if my wiring plan is correct... The intention is to run each SDS board off a Connex 500R SMPS as monoblocks using the XLR balanced inputs, while retaining "flick of a switch (or two switches in this case)" capability to run as two stereo amps off the RCA inputsAt present, the case I'm planning to use is rather small and may not allow space for a 2nd XLR, so may forego the R channel XLR connection option. Would like to check with the more experienced folks here whether this is feasible or advisable?Cheers all, and hello! <my first post 8-P>
I think the position of the switch is inverse to the top/bottom of the connections. When you flip the switch up it moves the slider inside the switch down, being on the other side of the fulcrum from the lever/toggle. Flip up to engage the bottom contacts, flip down for the top contacts.If you are unsure, just hook up a meter and check continuity between contacts with the two switch settings.
