0 Members and 4 Guests are viewing this topic. Read 1216674 times.
Is this kind of circuit typical in non-DIY amps? I ask, because I've never had this popping issue before. If it's a standard kind of thing, then I might consider it (e.g., any off-the-shelf amp I might buy---such as my QSC---likely has something similar). But if it's not typical for an amp to have something like this, then it feels like a band-aid to me; I'd rather solve the real problem than throw more circuitry at the issue.I also noticed that when I turn my SDS-470 off, one of the speakers makes a "farting" noise for about a second. It's like a "rippling static" sound. Fairly quiet, but similarly unsettling to the power-on pop/static.
I have almost eliminated my popping issue, and I wanted to share my theory, just in case it's both correct and relevant. First the boring history. I've been trying to tri-amp, then bi-amp my modified Klipshorns. The modification involved better (and much more efficient) midrange and tweeters, making the bass horn sound "smaller". I came up with the idea of passively bi-amping my 'horns, which means running two amps (SDS-224's) into the bi-wire connections of my crossovers. This would allow me to increase the gain on the bass horn to match the "too efficient" top-end. The bass amp now runs thru a 2.3 mH inductor that connects to the 6 ohm woofer (1st order Butterworth 415Hz low-pass filter). The second amp connects to a 48 uF capacitor (1st order Butterworth 415Hz hi-pass filter), then to the remaining crossover components and 8 ohm drivers. With this configuration, I would hear a loud pop when the amps were turned on. I just installed an active crossover, which eliminates these filters. Now the pop has been reduced to a small click! I'm no expert, but could the 48 uF capacitor have held enough of a charge to create a large discharge once the hi-pass amp was turned back on (causing the loud pop)? The hiss is still there, but as before, only when I put my ear a few inches from the top-end. Don't know why, but my popping issue is history. Mike
Did you check your amplifier output to see if there was any DC there?Holding a charge? A crossover capacitor doesn't work that way, it's not for smoothing DC, it is frequency selective, blocks some frequencies, while passing others. We're talking about AC.Wonder if the capacitor is problematic, leaky. Is the 48uF cap an electrolytic?
No, didn't check for DC.Mike
Matt my 470 seems to be making the same sound (farts) when I shut it off thru the left chanel sub woofer. It sounds strange like some kind of static discharging in the left sub voice coil?
The 12x12x4 Par-Metal chassis will work, but I went with the 16x12 to give myself a little more room in laying out the components and keep the power supply farther from the amp board. Also allows for other possible upgrades in the future (power supply, volume control, etc.). Chassis doesn't come punched for anything unless you special order it as such (costs extra). I've found them pretty easy to drill though I haven't gotten to the back panel yet. Just finished laying out the base plate for my mono SDS-450 amps. Did them mirrored since they'll be positioned side-by-side or behind the speakers. This actually made it easier to lay out and drill the second amp... just clamped them bottom to bottom and drilled through the first (only two of the power supply screws had to be relocated since that board is not symmetrical).I also drilled out the footer holes a little larger to accommodate some 1/4" shaft spikes I had on hand... I was only going to use three but found the amp too tippy with the big xfmr off to one side, so there's an extra hole at the front middle.
Thanks! I went ahead and ordered one a few days ago.I am confused about the transformer. So you have your Red and Black wires, but then there's also a purple wire. Going to the power supply, you have the blue and green wires. But what about the second set that is orange and brown? According to other people's setup, they just tape over it.Do I need to loop any of the orange / brown wires in closing them?
I don't know that I would rely on a few wraps of teflon tape. If you have a good sized Ace Hardware with hardware bins, you might be able to find some nylon shoulder washers with sufficient barrel length.
Matt my 470 seems to be making the same sound when I shut it off thru the left chanel sub woofer. It sounds strange like some kind of static discharging in the left sub voice coil? I never noticed this with the SDS254 or my Daton 240 plate amps. Im not getting the turn on pop though, hope this amp lasts because I love the control it has over the drivers.
You guys ever resolve the SDS-470 turn-off noise problem?
