0 Members and 8 Guests are viewing this topic. Read 1216620 times.
Is it true that the SDS-224 amp can have problems driving speakers over 8 ohms? If so, I may wire a 10 ohm resistor in parallel with the driver to bring the impedence down to around 6 ohms. Any comments?
Don't know if the SDS-224 has any problems driving 16 ohm loads, but if you put a resistor in parallel with the driver, the resistor would have to be a very large one with a power rating sufficient to dissipate the wattage. You would be dissipating more power in the resistor than the speaker driver, and in the resistor's case it would be 100% as heat. Steve
Hey guys I'm currently running an Audio-GD NFB12 DAC/Preamp with my SDS-224...The Mark Audio full range drivers are amongst the finest I've ever heard. If anyone is considering building a set of full range speakers. Put these at the top of your list. They won't disappoint.
Hey guys I'm currently running an Audio-GD NFB12 DAC/Preamp with my SDS-224. They're powering a set of Mark Audio Alpair 7 Gen 3 drivers. My other set is a pair of 15" Hawthorne Audio Silver Iris coaxial drivers mounted open baffle. The amp/speaker/pre sounds fantastic. I honestly couldn't be more happy with the combination. Powerful preamp, powerful amp, and truly wonderful driver.
Hmmm.I have a CDA-224 amp kit, and two EL70 (made by Mark Audio customized for CSS) 4" full range drivers just finishing break-in. I wonder what I should do with them .Seriously, thanks for the vote of confidence on the MA drivers sounding good with classD amps. I was waiting on a tube kit, but the vendor did not deliver. After that experience, more research and this thread led me to ordering the classD.
I am using a Connex 500 SMPS with one of the smaller SDS amps, and it works beautifully. it is light weight, a no-brainer to hook up, and sounds no different to me than the linear supply that I originally had with my amp (and sold to a work colleague). It is quiet (no hum, buzz, etc) and doesn't seem to radiate any untoward noise even though it is placed immediately next to the amp board in the chassis. The only down side to using the Connex supplies is the wait to get one (mine took about 30 days from order to delivery here in the USA). Seems to me that the A1000 would be a perfect match for the SDS 470.
What do you guys think would be an appropriate switch mode power supply (SMPS) for the SDS-470 in bridged mode? Perhaps something like this A1000SMPS from Connexelectronic? I'm thinking about building a pair of 800 Watt (at 4 Ohms) monoblocks with the SDS-470 board. I'd like to use a SMPS to reduce size and weight. Plus, I seem to recall at least one person reported success using Connexelectronic switch mode power supplies earlier in this thread.
Are SDS-258...I need it to manage both 4 Ohm and 8 Ohm speakers.Not sure this module can deal with 4 Ohm impedance.Do you know if we can adjust the gain with a dial (for each chanel outptut) ?
Awesome! Did you happen to measure power consumption with the SMPS? Switch-mode power supplies are supposed to be more efficient, right? That is one of my big goals with giving these amps a try: getting speaker power on par with my QSC, but with lower AC power.
