0 Members and 1 Guest are viewing this topic. Read 62335 times.
I have the bearing/motor at maybe 30 hours now and I do sense a subtle betterment with 'timing' or speed accuracy. So, it's pretty good at 20 hours...but seems to benefit from more time spun.
So, my earlier jab that unipivots might have weak bass may be nuthin' more than blather. It may well take time for the dielectric to break in.I'm a believer that it's the dielectric that takes the break-in time...not the wire itself. I've heard it countless times with every kind of wire imaginable. Teflon (which is probably what VPI uses) is the longest and plastic/poly, cotton and other materials are rather fast to nearly no time at all.
Get some male RCA's from Rat Shack - they don't have to be of any quality. Then get some solid core wire from Home Dopey. Solder the wire to the RCA jacks and put the free end into the cartridge clips (unsoldered) of the tonearm. Then plug the RCA jacks into your CD player. Plug the tonearm interconnect into a non-phono input on your preamp.Enjoy,Bob
Pity about the currency fluctuation for us poor Brits! Been quoted ?2470 for the Classic, arm & VPI's fitted Dynavector DV20X.Admittedly, that does not include the shipping I would pay if I bought from the USA but still seems a bit of a difference. Would be interested to know if anyone thinks this is an ok price here in the UK or whether there is a reputable dealer I can buy from in the USA as I note the deck is $2500 ( without a cartridge ) on USA internet dealer sites.
In the meantime, I will await further updates, from you, as the deck runs in and you satisfy yourself with both the sound and the set-up as a whole. Greg
About my only nit-pik about it is that the arm counterweight is not threaded to the arm, making fine adjustments for downforce a LOT easier. Outside of the mass-produced Japanese makes, this is not found in the specialist turntable world. Pity, as it makes adjusting for downforce/VTF much easier and removes one burden from cartridge/turntable setup.
John, the counterweight isn't threaded to the arm because the weight is offset. If you tried rotating the weight is would muck up azimuth big time. I thought the 10 had the weight adjustment at the end of the stub. Isn't there a hex screw at the back? This can be threaded in and out to fine adjust the tracking weight.
Quote from: mountaineagle on 28 May 2009, 07:51 amPity about the currency fluctuation for us poor Brits! Been quoted ?2470 for the Classic, arm & VPI's fitted Dynavector DV20X.Admittedly, that does not include the shipping I would pay if I bought from the USA but still seems a bit of a difference. Would be interested to know if anyone thinks this is an ok price here in the UK or whether there is a reputable dealer I can buy from in the USA as I note the deck is $2500 ( without a cartridge ) on USA internet dealer sites.Actually Greg, it doesn't seem too bad a price Here in US, the VPI Classic is $2500 and the Dynavector DV-20x is $680 = USD$3180. At today's exchange rate that's 1,997.15 GBP. The premium you are paying is 19.5% (before shipping costs added in....and its a whopper at 64lbs/~28kg)I assume you'd then get hit with 15% VAT upon entry into the UK? If so, your premium is 34.5%.Consider the screwing we in the US get if we want to buy, say, a similarly top-notch deck here in the Rega P-9. It costs USD$4995.00 here from dealers - that's 3,136.42 GBP.However, to buy that same deck in the UK (of course one would have to find one with the right pulley and 115v motor) it's 2542 GBP, or USD$4,046.86 or a premium of 19%.Seems similar until you factor in one grand statistic...that of VAT. As non-Brits, we shouldn't have to pay VAT of 15%. So, the real price for us non-Brits for the Rega P-9 bought out of the UK (again, assuming we can find it with the right pulley and 115v motor) is 2160.70GBP; or, USD$3,439.94. So, as it turns out, we are getting screwed to the tune of 31.2% premium over here for a Rega P-9. Reasonably comparable to the screwing you are getting at 34.5% after importation with VAT.Of course, you do have to factor in shipping to your equation, which may be another 60GBP for such a heavy table by US Postal Service (if they even ship this way - likely the cheapest option to the UK).How you may like the sound of the VPI Classic, or any table, is a subjective decision. But, how much do you pay in the UK there for a 29kg table complete with 10.5" arm? An SME arm alone in that size is likely to be 1500 GBP (just taking a swipe at it) or fully 40% of what the VPI Classic, arm and quality (fitted) cartridge would be.By almost any perspective, the table sounds at least, quite good. As well, your screwing is no worse than ours in buying Brit tables of similar ilk. I love spending someone else's money but, if you have it to spend it and need / want a new table.....you seem to be making a sound decision of a VPI Classic + Dynavector DV-20x for your hardearned cash on both and absolute and comparitive scale John (Business major, if you hadn't known previously )
Further to what has been mentioned previously I have been looking to buy an end of record tonearm pickup device like "The Lift" which is no longer available.Apart from checking our ebay has anyone any suggestions where you can buy one and, for a novice like me, will it be difficult to fit so it does not mess up the arm?Greg
I am dizzy,,,,,,,need to lay down and absorb all the infooooormatiionnnn
