Promitheus TVC passive preamp anyone?
0 Members and 1 Guest are viewing this topic. Read 605874 times.
guest1632
  • Guest
Re: Promitheus TVC passive preamp anyone?
« Reply #2040 on: 27 Jul 2007, 05:17 pm »
Hey ... good idea Ray
I'll tighten the nuts.
I did find an RA nut that was loose the other day but did not think :duh:
of tightening the rest.
Cheers mate :beer:
Jag
Hi Jag,
What 5687 preamp are you getting? You know you could get the one from Nick which uses a 6N1P. I think he sells it for $500 or so. Worth a look see on his site.
Ray
aod
« Reply #2041 on: 27 Jul 2007, 05:22 pm »
'Ello
Nick-san is doing a custom 5687 pre for me
 :P
Jag
guest1632
  • Guest
« Reply #2042 on: 27 Jul 2007, 05:27 pm »
'Ello
 :P
Jag
Hi Jag,
cool! So why did you pick the 5687 versus his 6n1p?
Ray
aod
« Reply #2043 on: 27 Jul 2007, 07:11 pm »
High Ray
I'm using JBL active monitors with Titanium tweeters. These tweeters are  a bit bright and I don't need to accentuate that any more. I do need richer mids and bass slam is not-compromise-able. :rock:
Thus the 5687. Only problem I fear may be the microphonics as these tubes have a reputation for that. I might use Herbies tube dampers to help out there if needed.
The JBL 6328's really slam, and add to that the 6312SP sub, WHOA NELLIE!. Just what the doctor ordered.
guest1632
  • Guest
« Reply #2044 on: 27 Jul 2007, 07:42 pm »
Hi Jag,
Not being familiar with the character of each of these two tubes, would the 6N1P be brighter than the 5687 tube?
Ray
High Ray
aod
« Reply #2045 on: 28 Jul 2007, 02:01 am »
Hello Ray
As a responsible manufacturer, Nick has used tubes that are in production. The 5687 is not a current production tube :thumb:
Both are good tubes but I guess the 6N1P was chosen by herr-Nick so that the strengths of the TVC would not be masked by the tube. The 6N1P is also a general all rounder.
For my case, I need the 5687 to tame my speakers  :icon_twisted:but ... the tube is quite microphonic.  :oSo, I have to go an extra step to help contol this, ie teflon sockets and qite likely, Herbies tube dampers. I might even have a protetion case around the tubes if I can't control the vibes.
regds
Jag
guest1632
  • Guest
« Reply #2046 on: 30 Jul 2007, 12:23 am »
Hi Jag,
It's a small ....
Nick tells me to put the Promi in front of the pre but then I would just lower the gain of the phono according to me. So I wonder if I could put the Promi between the pre and the power amp if necessary at all. Maybe that would give too high a voltage to the Promi. We'll see.
Shame on you giving up on the Allaerts, why?
Sorry it didn't work out with the Tannoy DMT's but it turned out to be too expensive to ship them to Singapore.
Still using the Living Voice?
Jos
ps. What on earth is Tad?
Hi Jos,
Gees, haven't we met somewhere before in a previous life? just kidding.
Hey Nick is correct. Put your pree so it is strictly as a buffer. Hook all your gear up to the TVC, and let it act as your volume control. Yeah, I'd hook it up and turn the TVC down to the second volume notch. Then adjust your volume on your pree, with music playing so that what you hear out of the speakers is just loud enough to hear. Now that just a rough guide. Then you'd control the volume with the TVC accordingly. Try that out.
Ray
guest1632
  • Guest
« Reply #2047 on: 30 Jul 2007, 12:50 am »
Ray, I replaced an Electronic Visionary Systems PB2SA that I had been using for over a decade. This is a dual mono stepped attenuator with 36 hand matched resistors/channel and star grounding. State of the art way back then. TVC blew it away for keeps. Putting it back in now makes me wish I had gone for the transformer setup a long time ago. There is a mechanical quality to the sound that, once I have heard it, I cannot overlook. Funny how that works. Like that tiny dent in your car: your eye goes right to it every time you walk past.TVC is like paintless dent removal for me :) Thanks again for the summary of your tweaking. Going into the hospital for knee replacement fri. Will have lots of time for tinkering during recovery.  Gerry
Hi Gerry,
I sure wish you the best in that knee replacement. Hope all goes well, with no complications at all.
Ray
Hi Gerry,
Let me correct something. Wehn you put the Black Hole Padding on the transformers, put a piece each on the top, and the two sides of the transformer's  U shape frame. Then if you get brave, you can put the BHP on the bottom of the transformer itself.
Ray
Gaara
« Reply #2048 on: 30 Jul 2007, 02:00 am »
Assuming you can get it.  Anyone else try to order some Black Hole Pad recently?
I order June 19th...still apparently out of stock.
guest1632
  • Guest
« Reply #2049 on: 30 Jul 2007, 02:40 am »
Hi Gaara,
I have a sheet sitting here. I can precut you some enough for all four sides of each transformer. PM me your address, and I'll see what I can do for you. Hey, someone helped me out, so I am just paying it forward. Glad to do it.
The 6.25 by 22, 2 strips one on the top underside and one on the bottom in between the two transformers, don't know I have enough for you there. But covering the frames of the trafos and especially underside, will go a long way to make this baby sing.
Ray Bronk
Whitese
« Reply #2050 on: 30 Jul 2007, 03:18 am »
i guess heat is not a consideration on these trannies....if they submerge them in tar in potted trannies, we can use dynamat kind of stuff without the worry..?
gooberdude
« Reply #2051 on: 30 Jul 2007, 03:24 am »
no heat whatsoever with these trannies...
i've used Black Hole Pad inside my TVC and recomend it for all TVC users.   I've used BHP in other areas, along with Dynamat.
Do NOT use Dynamat if possible...it deadens too much with too little of the product.   BHP seems to be quite pleasing, and not as easy to overdampen.
I have stuck BHP on my plate amps huge trannie, it gets hot but the BHP stays put.
Whitese
« Reply #2052 on: 30 Jul 2007, 03:27 am »
i better stop typing after 22:00hrs...i cant believe I compared an output tranny and its heat to the TVC's that deals in mV's...just tuck me in and say goodnite... :duh:
forget dynamat, i will try what you guys are using!
gooberdude
« Reply #2053 on: 30 Jul 2007, 03:33 am »
sleep tight!
Dynamat is excellent for damping metal in cars....it was designed to do this.     It can do harm once in the home, and in the hands of a 'phile tweaker though.      its real strong, muy fuerte en espanol.
as far as i know, there's no other audio specific material like BHP avail...is there????   damping material designed for trannies???
guest1632
  • Guest
« Reply #2054 on: 30 Jul 2007, 04:02 am »
sleep tight!
Hi, Black Hole Pad is actually for deadening speaker cabinets.
Ray
dgotlse
« Reply #2055 on: 30 Jul 2007, 08:00 am »
As  a happy owner of a Double Box Promi, I'd like to damp it with some BHP but Speaker City p&p costs for France are 29,99 $.
It doesn't make any sense to pay such an amount for a 7 $ order. Should somenone have an extra sheet of BHP to sell and ship at a sensible price, please pm me.
andrejko
« Reply #2056 on: 30 Jul 2007, 11:14 am »
gooberdude,
unfortunately BHP doesn't seem to be an option for us who live in Europe. Dynamat on the contrary is largely available. Did you perform any direct comparisons BHP vs Dynamat? Could you please clarify why BHP is in your opinion superior to Dynamat?
It could be also very useful for us novice tweakers if someone posted a pic of the TVC interior with damped trannies...
thanx for any feed-back.
gooberdude
« Reply #2057 on: 30 Jul 2007, 02:28 pm »
BHP is a MUCH better damping material for home audio....dynamat should only be used on metal inside your car.
i've used both to damp my Lovan rack, to damp speaker baskets and other assorted tweaking.   With only a small amount of Dynamat you can overdampen things REAL quick.
Any idea how much it would cost to ship to you??   i have 2 entire sheets, really only need 1.    i'd be willing to part with some or all of it for the right price....      BHP is cheap, its the shipping that jacks up the price.
from what i've read, BHP was designed to damp audio transformers.
Dynamat is like putting a strangle hold on items.    However, it simply rocks when applied to my car's doors and rear deck.
matt
Whitese
« Reply #2058 on: 30 Jul 2007, 02:30 pm »
yeah, I have my car doors and trunk lid lined with dynamat,,,,its like closing the doors of a Mercedez now....
guest1632
  • Guest
« Reply #2059 on: 30 Jul 2007, 02:41 pm »
matt
Hey Matt,
I'll betcha we could use the dynamat on the TVC, but in a sparing amount. Having no experience with it, would be hard to tell how much to use. Now, if you used the 6.25 by 2 on both sheets of steel, that just might be the ticket to dampen the steel plates. The BHP does dampen them but not a lot. It would be nice to rap on those plates and hear nothing, but a dull thud.
BHP might have been for trafos, but my first encounter was for use in controlling resonances in speaker cabinets.
I suspect the dynamat like the BHP is not only killing/dampening the TVC, but it would be also taking care of any vibrational stuff that would hit the TVC. That 2.5 by 1 under the trafos made a big difference in subtle details. Then adding the Grover cables, oh yeah baby. Next best things to having a tube preamp. Now if you have them as 3 by 1, underneath each trafo, you loose some detail, and the mids come to far forward. I'm using the screws which tighten down the trafos up against the BHP.All I know that it works.
Ray
