My tactics for improving vintage 3 way open baffles
0 Members and 1 Guest are viewing this topic. Read 30103 times.
Bumpy
Re: My tactics for improving vintage 3 way open baffles
« Reply #100 on: 9 Feb 2019, 11:51 am »
Lets look at the Bass driver amps etc. which will be run independently of the mid and tweeter.
I am taking a separate output from the speaker terminals of my power amp. It's difficult to get a real fix on the voltages involved but Googling reveals between 20 and 40 volts. This will need to be knocked back to 2 volts which is typical of line level.  As a reality check, it seems that most sub manufacturers build this into their kit, hence allowing a high level input in addition to the line level input.
A forum friend has purchased for me a unit like this.
https://www.ebay.co.uk/itm/SPEAKER-TO-RCA-CONVERTER-HIGH-TO-LOW-LINE-LEVEL-ADJUSTABLE-ADAPTER-2-CHANNEL/361987845604?hash=item5448282de4:g:gPoAAOSw~o5ahv5-:rk:5:pf:1&frcectupt=true
It looks to be suitable but with a 40 to 1 reduction he has modified that to just 20 to 1 with a change of resistors. I should get it in the post next week hopefully with a diagram of whats inside :)
If this works OK by feeding the resultant signal to a Rotel integrated amp then I am good to go on ordering the MiniDSP to set up a low pass filter.
Long term there may be higher quality speaker to line level converters that I can get, but for now its a step forwards.
Bumpy
« Reply #101 on: 18 Feb 2019, 11:33 am »
My matching super tweeters are now in place. The mounting is intended to get the voice coils of all drivers close and in the same vocal plane.
Initially they are upward firing and a variety of caps are available to set the high pass frequency. Let the experiments begin. :)
Bumpy
« Reply #102 on: 18 Feb 2019, 05:56 pm »
Result.
With a 0.47uF capacitor they have slipped into the OBs perfectly. Their presence can’t be detected, but there is an additional ‘air’ to the presentation which I like a lot. I suspect as they run in, there may be further gains.
Happy boy. Thanks Matevana for the recommendation
Bumpy
« Reply #103 on: 14 Apr 2019, 12:21 pm »
I am now looking to improve the 4" high frequency drivers.
I have available vintage Alnico drivers including Saba, 'small' magnet Grundigs, larger magnet Grundigs and my latest purchase is a pair of Klangfilm drivers. These have BIG horse shoe magnets (see picture)
If the weight of drivers correlates to the weigh of the Alnico magnets there is an interesting comparison.
Sabas  105gm
'Small' magnet Grundigs 236gm
Larger magnet Grundigs 330gm
Klangfilm 555gm
« Reply #104 on: 14 Apr 2019, 02:46 pm »
Wow, looks a great driver large magnet, how is the sound from this driver?
Bumpy
« Reply #105 on: 14 Apr 2019, 02:58 pm »
Just got them and at present I have only checked that they are working OK. Certainly sound more alive than the Grundigs they will replace.
They don’t have screw holes, so I need to find a way to mount them. :)
« Reply #106 on: 14 Apr 2019, 03:17 pm »
The pressure ring dont came with the driver?
The magnet cover cant be put near metal.
Bumpy
« Reply #107 on: 14 Apr 2019, 03:46 pm »
No there isn’t a pressure ring, but the drivers are probably 65 years old so they went missing along the way.
My drivers are recessed into the baffle from the rear so may hold them in place with a rubber strap stretched across the magnet and fixed into the rear of the baffle either side of the driver.
« Reply #108 on: 14 Apr 2019, 03:53 pm »
Wood or alu rings are the material less prone to disturb the magnet.
Bumpy
« Reply #109 on: 14 Apr 2019, 04:01 pm »
Good suggestion. I am currently thinking something like this. https://allensportsusa.com/products/4-rubber-straps.
This will also add some damping.
« Reply #110 on: 14 Apr 2019, 04:25 pm »
How these belts could be implemented?
Bumpy
« Reply #111 on: 14 Apr 2019, 09:52 pm »
I will post a picture when I experiment later.
Bumpy
« Reply #112 on: 18 Apr 2019, 02:17 pm »
Here's a picture of a cobbled together prototype.
« Last Edit: 18 Apr 2019, 03:29 pm by Bumpy »
« Reply #113 on: 18 Apr 2019, 04:16 pm »
Hm, there is any photo from the face cone side?
Bumpy
« Reply #114 on: 18 Apr 2019, 05:48 pm »
There will be one along later :)
« Reply #115 on: 18 Apr 2019, 05:51 pm »
There is any space for metal clamps?
Bumpy
« Reply #116 on: 19 Apr 2019, 07:22 am »
No room for metal clamps in my baffle, but this system will work out ideal. From the front one would never know.
Bumpy
« Reply #117 on: 27 Apr 2019, 06:29 am »
I have now found a very suitable amp for bass duties. With DSP there are additional demands on the amp to provide power at specific frequencies. This places big demands on getting it right.
This amp delivers 1000W of quality sound per channel into 4 ohms. That should suffice.
« Last Edit: 27 Apr 2019, 12:34 pm by Bumpy »
Bumpy
« Reply #118 on: 11 May 2019, 09:50 am »
I am so pleased with the way my system is developing. The ICE power works perfectly. It is capable of delivering 2x1000W into 4ohms and drives the 15" Altec 416 8A beautifully. My low pass filter is set at 80Hz at present with 24bd slope.
To remind you, the midrange SEAS Exotic W8 runs full range without any cross overs and the high frequency Klangfilm 4" has just a single capacitor for high pass.
My next task is to upgrade the signal path to the ICE Power. This will involve a custom built voltage divider to replace the £6 device from E Bay, a linear power supply for the miniDSP to replace the existing switching power supply, and installation of a MUCH better volume control than the relatively OK pot installed at present.
It seems a lot of trouble to go to for frequencies below 80Hz, but I am discovering more and more that its these low frequencies that underpin and carry along any tune.
Pictures to follow.
Bumpy
« Reply #119 on: 11 May 2019, 12:50 pm »
There is one other thing I need to try.
Now my 211 triode amp is removed of the need to drive the 15inch bass, the triode amp has a much easier life.  My intention is to substitute the 20 watt 211 amp with 1.8 watts of DRD 45 triode amps. The sweetness of the 45 triodes needs to be investigated.
