0 Members and 1 Guest are viewing this topic. Read 40128 times.
The OP said he was not into tinkering, so I doubt this option would have great appeal to him. That's why I suggested Rega in the first place. In all the years I've been listening, I've never adjusted VTA ( and please don't tell me what I'm missing).
This guy gets it. I don't want to tinker with shit. I want to put on a favorite and listen. I want the nicest and simplest setup for under $1500.
Even if you don't wanna '' tinker'' I still consider reasonably easy VTA adjustment an absolute must. You do wanna get the VTA right, correct? Just like all the other setup parameters. Carts come in different heights, and for some stylus profiles nailing correct VTA is critical to good sound. It can be the difference between so-so and eargasm. So achieving a correct VTA is important. You don't need to be an OCD hand wringing tinkerer to wanna get VTA right during setup. An arm that offers VTA adjust is just another setup tool, no different than VTF and bias and null points. Having it available is not necessarily a gateway to extreme tinkering nervosa, or some rabbit hole that's gonna send you into an OCD tailspin. Personally, I would never buy an arm without VTA adjustment. It's just too important, and without it you may never achieve the true glory your cart has to offer.
And, Mr. Gandy is not stupid. But, he knew many of his customers might be so his entire turntable is pre-programmed. Wayner
I see that tact reigns supreme on this site. Though I own a Rega, I really don't take offense at these remarks. I don't think they're meant as an insult. But perhaps some here should reread their sentences before posting just on the off chance that their comments might be misconstrued.
Sorry, I'm an engineer, not a writer. Sometimes the truth needs to be brought right out front for everyone to see, not beating around the bush.
There are other tables in the price range including Music Hall, ProJect, Thorens, Pioneer and more, plus slightly used like Clearaudio/Marantz. For a successful experience, all of them require more than just putting a record on.neo
It's really not as complicated as it may seem. Trust me. It's just the anxiety of the unknown. There are really only a handful of important setup parameters, and once the penny drops, the concept of what you are doing and trying to accomplish is completely logical and makes complete sense. It's not mysterious hoo-doo voo-doo. It's just distances, angles, and weight.I'm self taught in setup, just from reading and talking to experience. I currently run 2 tables and 4 arms / carts. Set it all up myself, never had a helping hand, even as a beginner. And all sound great. I even make arc protractors for all my arms. I find them the quickest / easiest way to get perfect overhang / effective length, provided your mount distance is spot on. I'm neither an engineer nor a technical person.Don't get lost in the minutiae. It's neither onerous nor overwhelming, and you don't need microscopic precision. Some folks just like to make it out that way.
