0 Members and 1 Guest are viewing this topic. Read 40123 times.
and no table. I want something better than a Pro-Ject Debut Carbon but not looking to spend $2000 either. And, whats with all these tables coming without a dustcover? You have to pay another $250 for that. Right now I am thinking either one of those marked down VPI travelers at Music Direct or a Scout Jr. I would really like to stay below $1000.
Of course, I'll recommend a table I use, the Rega RP6. But you'd have to increase your budget to a bit over $1500 with an Exact 2 cartridge. ( I got a great discount at Music Direct). Regas have great sound and are truly set and forget tables. If you like to fiddle, they're not for you, though you can upgrade. In all the years I've owned Regas, I've had only one issue: the cueing arm had to be replaced after quite a few years, this was on a Rega 25. The RP6 is a different and much better table, IMO. And, BTW, as I posted in this circle, I sold my $12,000 Acustic Raven and bought the Rega. To me, the sound is every bit as good.
Thanks for this info. I should have mentioned, I am new to turntables and I want to set it and forget it. I don't want to fiddle with anything.
I bought one of these and sent it back. There were some issues with it that I did not like. As I recall, the arm doesn't have a lock, or if it did, it was not very good and the possibility of an accident was very high. Not a horrible deck and it might be OK for a first time guy.'ner
geowak, The Merrill deck may be on the list, but I haven't really heard it, but it did make Product of the Year by Absolute Sound recently. And I certainly like the Jelco arm on it. I wish it was a DD table tho.'ner
