HD audio converter file format and resolution (software)
0 Members and 1 Guest are viewing this topic. Read 97843 times.
audiventory
  • Yuri Korzunov, AuI ConverteR 48x44 developer
    • AuI ConverteR 48x44 - HD audio converter for high resolution files
Re: HD audio converter file format and resolution (software)
« Reply #100 on: 27 Apr 2017, 08:15 pm »
WAV to mp3 Converter for Mac OSX and Windows https://www.youtube.com/watch?v=g2-c2I368rY
audiventory
« Reply #101 on: 29 Apr 2017, 07:48 pm »
How to Assign Target Directory for Converted Audio FIles https://www.youtube.com/watch?v=DxS01n3OHyY
audiventory
« Reply #102 on: 30 Apr 2017, 07:33 pm »
Free mp3 Converter for Mac and Windows https://www.youtube.com/watch?v=1vpfrUgkjD8
audiventory
« Reply #103 on: 2 May 2017, 07:34 pm »
Free Audio Converter for Mac and Windows 10, 8, 7 https://www.youtube.com/watch?v=yeFzK4_0F6s
audiventory
« Reply #104 on: 3 May 2017, 05:52 pm »
How to Convert ISO to FLAC under Mac and Windows https://www.youtube.com/watch?v=bXcqWrO8OnM
audiventory
« Reply #105 on: 4 May 2017, 05:19 pm »
Tutorial: How to Convert ISO to FLAC under Mac and Windows http://samplerateconverter.com/content/how-convert-iso-flac-under-mac-and-windows
audiventory
« Reply #106 on: 9 May 2017, 06:36 pm »
How to Improve Sound Quality of playback device (DAC, music server, portable digital audio player, mobile phone, etc.) via audio file optimisation http://samplerateconverter.com/content/how-improve-sound-quality
audiventory
« Reply #107 on: 18 May 2017, 03:09 pm »
audiventory
audiventory
« Reply #109 on: 4 Jun 2017, 06:25 pm »
audiventory
« Reply #110 on: 27 Jun 2017, 08:23 pm »
What is FLAC File. Quality issues http://samplerateconverter.com/flac
audiventory
« Reply #111 on: 30 Jun 2017, 05:58 am »
DFF to FLAC Converter for Mac OSX, Windows.
Features, Configurations, Quick start
http://samplerateconverter.com/dff/dff-flac-converter
audiventory
How to Choose the Best CD Ripping Software
« Reply #113 on: 15 Jul 2017, 06:28 pm »
Read about sound quality issues, different ripping ways (including safe/secure and unsecure), ripping formats and settings, metadata management are revieved http://samplerateconverter.com/educational/best-cd-ripping-software
jtwrace
    • TIPP YouTube Channel
Re: How to Choose the Best CD Ripping Software
« Reply #114 on: 15 Jul 2017, 06:34 pm »
Can you rank (in your opinion) the best to worst rippers?
audiventory
« Reply #115 on: 15 Jul 2017, 06:43 pm »
I can't do it, because I'm developer of one of rippers.
So I consider my software as the best.
But it is not independent opinion :)
I hope, that some independent person will make independent comparison of the rippers by error steadyness.
jtwrace
« Reply #116 on: 15 Jul 2017, 06:46 pm »
Why not?  I don't see any reason why you wouldn't rank yours #1 but I'm curious to know what you think of the others.  In fact, how do you rank dBpoweramp since it does things that yours and the others can't such as rip using a robot.
audiventory
« Reply #117 on: 15 Jul 2017, 06:54 pm »
I do internal researches, but I can't show results by ethical reasons.
Automation is very important thing for big number of ripped CD's. As far as I know, there are some special device, isn't it?
Also one ripper (I don't remember it's name) use several drives for faster ripping.
I also have ideas about same functionality, but without special hardware - only standard drives.
Estimation of the ripping software is complex thing (complex of features for certain task).
jtwrace
« Reply #118 on: 15 Jul 2017, 06:57 pm »
I think without giving an opinion and backing it up without data isn't any better though.  You're entitled to give an opinion so long as you're not bashing the competing product.  I'm not looking for that either.
audiventory
« Reply #119 on: 15 Jul 2017, 07:40 pm »
If says about quality for base of opinion need results of test (that is not public available currently).
Often I read in a forums, that "ripper N is the better than M". But it is feellings only.
Real figures may show that M is better than N.
Other people says, that a ripper is the best, because it use checksum database.
But after writing it in the formulas we can see that there is not all so simple as look at first sight.
I think, that it is need to make efforts to increase correct error detection probability without refering to external non-certified database.
When we read audio data as raw stream with error flags, we can to try restore damaged data even.
Such algorithms is "Paranoia" (open source) and Audiophile Inventory's "Ripping with deep error control".
As far as I know dBpoweramp use same algorithm, like described in my article.
These algorithms have common base, but different implementations.
So need practically check their abilities in figures to correct conclusions.
Also there are different kinds of disc damages, that can change test results, I suppose.
In the article I wanted to say, that we can't rely to feelings in CD ripper estimation.
We can't say that ripper #1 have more transparent sound than ripper #2.
Errors of CD ripping are coarse enough.
In my ripper I like interface: open tracks as usual files (cda or aiff), no settings for user, one window for use action.
Though, while I don't apply automation for big number of ripped CDs, that done by some competitors.
iTunes have access to the best metadata database Gracenote (paid for commercial software).
XLD is free for Mac only (I don't know about its error detection algorithm).
CDRtools (cdda2wav+"paranoia") is free for Windows only.
It is impossibly univocal rank geterogenous advantages, I suppose.
It is need to consider the ripping tool for your task.
As example, some people look for fast ripper.
But audiophile ripping is not fast, because there are re-reading and error detections with speed adaptation are used.
Etc.
